17 Jul 2024 at 21:52 #21 Loki Loki Soldato Joined 17 Nov 2004 Posts 10,234 Location The Republic Pinball-Fantasies said: They are about another £300 + ( RTX4050-RTX4070 ) then the Lenovo Ideapad Pro 5 16" Click to expand... I'd take a look around @Pinball-Fantasies you can deffo pick up a 16" RTX 4050 for under £800 in a non gaming chassis
18 Jul 2024 at 15:57 #22 Scrutinize Scrutinize Soldato Joined 4 Apr 2003 Posts 8,118 Loki said: I'd take a look around @Pinball-Fantasies you can deffo pick up a 16" RTX 4050 for under £800 in a non gaming chassis Click to expand... Pinball-Fantasies said: They are about another £300 + ( RTX4050-RTX4070 ) then the Lenovo Ideapad Pro 5 16" Click to expand... Initial budget was c£1400 based on your spec? I was assuming this was an Asus Zenbook or equivalent. Switching from an ultra portable to an RTX equipped machine would get you something decent in budget. An RTX Ultra Portable won't be cheap though at the 32gb/Ultra 9 spec. Dell XPS 14 with RTX 4050 and 16gb / Ultra 7 is £1500 Depends what you need as your priority. Very different use case if you want to stay at the 14" ultra portable size vs the 16" Lenovo.
