I have a Cooler Master Hyper 212 RGB Edition cooler. A bit confused where to plug in the RGB connector on a Gigabyte Z690 Gaming X Mobo. I'm new to RGB and it's a little unclear from the labels on the mobo and the details in the manual. The connector is a 4-pin female type.
Next to the CPU_Fan header there are 3 other headers. One is CPU_Opt, which from the manual shows as 'Water cooling CPU fan header'. The next one is labelled 'G DV' and is a 3-pin connector. The manual shows this as 'D_LED1/D_LED2'. The 4th header is a 4-pin labelled 'BRG 12V'. In the manual this shows as 'LED_C1/LED_C2'. I thought this was the correct header. But the manual details this as being for 'RGB LED strip headers'! :-/
The cooler does come with a controller. Do I just need to use this? Kind of imagined I'd be able to connect it to the mobo seeing as it's a pretty new model. As I said, new to RGB. This is my first RGB device! So
