Can't pass POST - CPU & DRAM light stay on - Any advice before ASRock RMA? CMOS battery? [AM5]
3 Jun 2019
Hello, please help/advise,
Self-built PC which has booted previously just fine. Now can't POST. LEDs and fans power up. Power indicator lights blink.
[Motherboard] = ASRock PG Riptide (AM5) - POST status check lights stay illuminated for "DRAM" AND "CPU".
Cannot get to BIOS.
[Things I have tried]
Removed dGPU but even on integrated no display.
Pulled out all perephierals and tried both RAM sticks individually/switched.
(+EDIT) Cleared CMOS by shorting the Clear CMOS pins. PC is normally fully powered off and sometimes this kind of boot would be an intermittant fault, requiring a few restarts to turn on, might this explain anything???
[7600 cpu], is it worth thermal re-pasting? Something else worth trying before sending back to ASRock (<1year since purchase)?
Appreciate any advice, thank you
How new is the build? is this something that has been working for months without an issue then suddenly started or is it a new build thats been working fine for a few days\weeks and now has died?
What make\model ram do you have and what cpu cooler?
I would try the following
- Move the ram to the other slots
- Remove the cooler, check for any bent pins on the motherboard or any paste in the pins
- Disconnect and re connect all the cables to the mobo.
Not sure if any of these will work but it could be the fact that the mobo has failed
Thanks for the reply ED209.
(+edit)
RAM = G.Skill Trident Z5 Neo
CPU is stock Wraith(?) AMD cooler for Ryzen 7600
Its been working for months and months BUT recently at times these same symptoms would appear intermittantly (and normally resolve after a couple of power cycles (pressing the reset button or holding power button down and booting on again). I realise now that it haas never been a monitor/display/GPU problem.
I will try your above again. Ordering in some thermal paste so may be a few days. Cant think of anything Ive done to bend pins but will try all . Thank you, stand by :)
Do you mean swithing off at the wall?
If so try just shutting down windows but leave the PC plugged in and power switched on. Think maybe it could just be the constant power cycles causing the problem.
What's the PSU?
Sorry to spam posts (can't seem to edit).
Now I have re-pasted and installed third party CPU cooler. Now even worse/less happening.
RAM sticks are RGB and now no longer light up AND power button now does nothing ; no power light , no fans spinning up.
Just as soon as PC receives power from wall the motherboard LEDs light up along with the POST lights for CPU and DRAM.
So... CPU and/or RAM. Both of which I bought in Canada <1 year ago. Live in the UK. Could RMA them and get shipped to a friend in Canada who is due a visit. Feel silly now thinking CPU and RAM rarely fail. I suppose it could be PSU failing slowly
This might be the problem, can you share whole system specs, including a GPU if you run a dedicated one
7600 (AM5)
ASRock PG Riptide B650M
GSkill Trident Z5 Neo 6000 2x8gb
Corsair TX550M (Gold?)
Normally running nVidia 3060Ti since problem started I have tried to boot on integrated graphics.
PC sits in one of those cabinets under the desk. If the door is closed PC will freeze (happened a handful of times mindlessly) as obviously there is no cooler air. I have given my chip an iso rub with a toothbrush as due to the design of the chip I was wondering whether the thermal paste from pre-applied stock cooler had ran on to the chip itself perhaps after an overheat.
Is it possible 3060 on peak power that my PSU has failed?
Appreciate any help, right now Im thinking is it my CPU? RAM? PSU? (then MOBO?)
7600 (AM5)
It’s very likely heat related.
Yeah 100% a heat problem, everything's getting far too warm in a confined cabnit door open or closed, I would recommend moving your pc where it can get a good amount of airflow around it as a start.
PSU may have already cooked it's self because of the heat
If I may necro my own thread.
Replaced PSU , only get motherboard lights when PSU plugged in. Power button does nothing and fans don't spin.
To make my nightmare worse, I have damaged one of the RAM slots (B2), Can the RAM being in the wrong slot prevent boot?
or
Have I fried my motherboard?
No LED or anything happening when Power button is pressed. (Checked all cables plugged in)
No difference with or without GPU.
Changed PSU and CPU cooler, after that the fans didnt even spin but that might be because I damaged one of the four RAM slots. After these changes I dont even get the POST
Pulled and re-plugged in the Power buttons/Reset/LED headers.
I think, given my heavy handedness with the motherboard that I may have well have broken something or it is the CPU that is dead as previously suggested. POST status check lights dont turn all at all (just some other lights on the MoBo
Thanks for any advise
As I've already said, the most likely cause is the CPU.
You haven't said what colours the debug LEDs are, but I'll hazard a guess as a red CPU LED and an orange DRAM LED.
If so then it's almost certainly a flaky CPU SOC/memory controller = CPU RMA.
AMD warranty is international so you don't need to ship it back to Canada for the RMA.
If you've now damaged something else in the process of p1!ssing around with troubleshooting then I can't help you more.
Was indeed DRAM and CPU debug LEDs. CPU died a slow (non-instant) death.
Thanks for letting me know AMD RMA is International. I will try that before any more p1!ssing around and breaking anymore RAM slot connectors so that I know cant RMA my motherboard probably.
