- 22 Nov 2007
Car: Citroen C1
On Sunday, the low oil pressure light came on while i was on a dual carriageway doing 50mph, immediate thought was to divert to a garage that was about 2 miles away and was near to the supermarket i was going to anyway. After two mins the light goes off and i'm thinking ok thats weird but it must be a good thing right? I drive it home 10 miles all good no problem. Yesterday i dropped my wife at the station (3 miles eachway), pulling into my road is a tight turn and after that the light comes back on( not sure if any significance?).
Parked it up (my space is on a slight slant) checked the dipstick which is dry. Spoke to a mechanic as its due for MOT next week he said put some oil in which i will try today. I don't recall hearing any loud knocking noises but i'm already thinking what if the engines knackered. Why would the light come on and then go off and be fine for about 12 miles until coming on again??
For context, i've had the car since last August after 15 years of not having one so my maintenance knowledge isn't good. I do know to check tyre pressure but beyond that..
I did have it serviced in January so i thought i was good for the year but the manual says to check oil every 3000 miles , doh!
