Not done a build for a very long time so asking about almost every step as I go. I've pretty much settled on a the 7800X3D as my CPU and am leaning towards a DeepCool AK620 for cooling. I have no plans to overclock and will probably be having a play to get the temps down to the absolute minimum once I'm up and running. As I understand it, the stock setup with AMD CPU's is they simply drive up to the 95deg limit. So a bigger cooler just means they drive harder? I assume you can limit the max temp somewhere so the fans are not constantly maxed out. I want them all but silent if I can use settings to do it??
My basket at OcUK:
My basket at OcUK:
- 1 x AMD Ryzen 7 7800X3D Eight Core 5.00GHz (Socket AM5) Processor - Retail (SKU: CP-3DT-AM) = £329.99
- 1 x Samsung 990 Pro 1TB M.2 2280 PCI-e 4.0 x4 NVMe 1.3c Solid State Drive (SKU: HD-24Q-SA) = £109.99
- 1 x Kingston FURY Beast EXPO 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit (KF560C36BBEK2-32) (SKU: MY-29T-KS) = £104.99
- 1 x Gigabyte B650M Aorus Elite AX (Socket AM5) DDR5 Micro ATX Motherboard (SKU: MB-5BE-GI) = £164.95
- 1 x Asus GeForce RTX 4070 SUPER Dual 12GB GDDR6X PCI-Express Graphics Card (SKU: GRA-ASU-01517) = £569.99
- 2 x Arctic P12 PWM PST A-RGB 0db Black Triple Fan Pack - 120mm (SKU: FG-058-AR) = £34.99
- 1 x DeepCool AK620 Zero Dark CPU Cooler - 120mm (SKU: HS-01K-DC) = £58.99
Total: £1,408.88 (includes delivery: £0.00)
