New PSU advice?
26 Dec 2021
Sowerby Bridge
I am looking to buy new PSU and came across this,
MSI MAG A850GL or Corsair RM850x SHIFT.​
Which one to go for guys warranty is better with Corsair but is it better?
Thx
So which one would you choose out of A850G or the SHIFT ( im not bothered about cables, just quality and performance).
Thanks!
From what I can see in reviews, the A850G and SHIFT are both built by CWT and the components listed for each model are very similar, but the SHIFT is supposed to have been updated with the revised 16-pin (12V-2x6) connector, is likely to be higher volume (so might have been improved/modified more, relative to the MSI) and Corsair's support used to have the better reputation.
Thx m8 SHIFT it is.
