- 26 Dec 2021
- Sowerby Bridge
So which one would you choose out of A850G or the SHIFT ( im not bothered about cables, just quality and performance).SHIFT is better (if your case supports side mounted cables), MSI's comparable PSU is the A850G.
From what I can see in reviews, the A850G and SHIFT are both built by CWT and the components listed for each model are very similar, but the SHIFT is supposed to have been updated with the revised 16-pin (12V-2x6) connector, is likely to be higher volume (so might have been improved/modified more, relative to the MSI) and Corsair's support used to have the better reputation.So which one would you choose out of A850G or the SHIFT ( im not bothered about cables, just quality and performance).
Thanks!
Thx m8 SHIFT it is.From what I can see in reviews, the A850G and SHIFT are both built by CWT and the components listed for each model are very similar, but the SHIFT is supposed to have been updated with the revised 16-pin (12V-2x6) connector, is likely to be higher volume (so might have been improved/modified more, relative to the MSI) and Corsair's support used to have the better reputation.
Another option is the Asus 850w tuf gaming.Thx m8 SHIFT it is.
