Plus artic has very good support, op if you think you need a top up contact about a refill.
Can you not refill it
I know it is not meant to but surely taking out the cooler and refilling or even topping up is not impossible?
I did post a link earlier for the service kit.It's quite doable. A couple of years ago they had that issue with the Freezer II AIO gasket degradation. They sent out a service kit to fix it which involved opening it up, and you could replace some of the potentially lost coolant at that point.
£46 shipped as I type this.
In my head though £46 for a 360mm seems too cheap? Like when they take their profit, it doesn’t leave a lot actually spent on quality parts?
I remember Thermalright from the Half Life 2 era, had a couple of air coolers and maybe a gpu cooler with the little ram heatsinks, and they were never ridiculously cheap
Makes you wonder if a different company has bought the rights to use the name.
Both, but weighing heavily on the latter. The fans that come with some of those expensive AIOs are also atrociously poor. (Looking at you NZXT and Corsair)Is it that the Arctics are cheap, or the other brands are ludicrously expensive?
Yes you can. Just remove the detachable VRM fan and you should be able to connect the other cable.The only fault (and I use the term loosely) is you can't switch from the all in one cable to the split connector without unmounting the cooler from the CPU as far as I can tell anyway?
Is there an issue with these that I'm not aware of that people are avoiding them?
Not a very good picture
Arctic Freezer 420mm fitted in the Front of my Evolv X case
It's a bit off topic I suppose but how reliable are these Arctic AIOs? Are they prone to leaking? I've always gone for a decent air cooler instead of AIOs because I've always thought they're capable of leaking
