No opentherm is a communication protocol between the boiler and thermostat. Rather than simply among the boiler to be on or off it can ask for a specific flow temperature with the aim to run more efficiently.I spoke to the guy who will be doing the boiler switch along with some maintenance work and he said the weather compensation sensor is useless, he suggested a indoor controller with a temp sensor would work better. Not sure if that's what OpenTherm refers to? I need to read up on it to educate myself...
Rather than cycle on and off constantly at 60c it will stay on at 25c for instance. You don't get spikes in room temperature either.
Your boiler and your there need to support it.
If an engineer doesn't know what OpenTherm is at this point (it's nothing new) id suggest they're a bit rubbish.
