- 25 Apr 2011
- Crawley/Gatwick
Evening,
I have been trying to get the card working for weeks now. Fresh windows install, all updates, new drivers, latest bios
After installing restart is required, boot until logo is fine but then straight after it hangs, takes a while to get to login screen, then logging in takes a while. Upon running games/bench no drivers found
Device manager code 43 on the gpu
Sometimes card works as if nothing is wrong but thats on a rare occasion
Tried 3 psus, 650, 850, 1250 gold rated all resulting in the same issue, swapped ram, reset bios, running without amd-xmp
RMAd the card, ocuk ran multiple tests no error found:
NFF - Reported struggling to boot, getting stuck on BIOS splashscreen or hanging on blackscreen with driver errors - Installed in a 7800X3D system and connected to a 1440p 144Hz display with no issues booting to desktop and loading drivers. Shutdown and restarted to confirm and then restarted to confirm all display outputs operate with no issues. Put under load in games and benchmarks and restarted at random intervals with no issues loading back to desktop and applying drivers. Returned no fault found
I am lost, read most of googled issues/solutions, nothing
Can someone shed some light onto this or point me in the right direction
So frustrated as had rtx 3070 prior to rx7800 and it was flawless
Amd 5700x, b550m wifi plus ii, 16gb ram
