OcUK Staff
- 15 Jul 2022
- OCUK HQ
Well, we didn't see this one coming! Known for their legendary gaming mice and gaming surfaces, Endgame Gear has knocked it out of the park with an awesome Hall Effect 65% Gaming Keyboard.
With an all-black finish, RGB lighting, 65% form factor, and Gateron KS-37B switches, the Endgame Gear KB65HE might just be our new bae .
Hall Effect Technology
The tech so good it snuck its way into the name. Unlike traditional mechanical switches you’ll find on any run-of-the-mill gaming keyboard, Hall Effect switches utilise a magnetic dual-rail structure. This provides you with an ultra-smooth, action and swift rebound. Essentially, keystrokes are registered through a magnetic field sensor, allowing for improved accuracy, among other features. Cool right?
Notably, this technology allows you to customise the Endgame Gear KB65HE Hall Effect Gaming Keyboard’s actuation distance between 0.1mm and 4mm.
RGB – Premium Build Quality – Rapid Trigger Tech
This awesome sauce doesn't stop with the hall effect either. The Endgame Gear KB65HE is kitted out with Rapid Trigger Technology (try saying that ten times fast). RTT does pretty much what it says on the tin; you’ll benefit from lightning-fast response times and super-high precision.
Did somebody say RGB !!! *slaps roof of Endgame Gear KB65HE* “This bad boi can fit so many colours in it”
Per key lighting, key bindings, and more are all customisable in the pretty awesome KB65HE Configuration Software. While we’re still on the topic of pretty things, overall, Endgame Gear has come out swinging with this keyboard. It’s hitting all the right notes, and damn we’re here for it.
All of the KB65HE sexiness is confined to a stylish block of CNC machined aluminium with rounded corners and a silicon grip on the bottom. What’s more, not one but two sets of feet are included, allowing you to choose the perfect angle.
Ready To Game?
If dominating the competition is on your 2024 goal list, then you won’t want to miss out on this bad boi. You can check out all the deets over on the overclockers uk blog.
A few times I've been around that track
So it's not just gonna happen like that
'Cause I ain't no Hall Effect girl
Ready To Game?
Endgame Gear KB65HE 65% USB RGB Gaming Keyboard, Hall Effect Gateron Switch, ISO UK - Buy Now
Been deep cleaned every 6 months or so.
