ive never personally have an Asus motherboard not give me crap. all the way back to LGA 1150, ever board as messed me about in some way so not i just avoid them
All brands are capable of having a bad board. Looking at individual board features; VRM features in particular, will better steer you.
four old Asus routers boxed away all in working order
Haven't touched one in awhile but never been impressed by the stock firmware on Asus routers - in the past you pretty much had to use the Merlin modified firmware to get stable, full feature working, operation. Both of the Asus routers I had developed silly issues - the power button stopped working on one and when I opened it up it was a really really cheap part with like 1/10th the rating for operations, etc. compared to the next most expensive part which was like 2p more, probably less when bought in large bulk.
Which has been the story for me when it comes to Asus stuff - even the supposedly premium tier stuff they cheap out somewhere and put like some really cheap and nasty generic capacitors or something like that... I've opened up more than one ROG Swift designated models i.e. the original G-Sync monitor to find they've had to do some rectification of silly design faults post production where stuff has just been slapped in place with silver tape to fix it... which ironically wasn't the point of failure that was killing a lot of them.
Sure there are plenty of people who have no problems with Asus stuff, but I won't touch them personally now after my experiences over the years.
bless, this one is young he as not yet seen the path...
when your 20 or 30 year deep you will see some are a lot worse then others
Complete nonsense. I've been building PC's since x386 and 486 and had all manner of motherboards.
I've only ever had one board failiure and that was a Gigabyte... but to be fair it was probably 10 years old at the time.
i still wouldn't rule out buying a gigabyte board... I just buy what I need for the best price at the time.
tbf yerAsrock = Best value for money
that doesn't change the fact some are a lot worse than others.. i mean AM5 Asus they put out a bios to fix a problem and put in the notes that using it voided your warranty
7800X3D voltage issue while overclocking
What parts do they cheap out on?Gigabyte = cheap out on components
As to Asus power button, ironically I never turn them off
On the new X870 they are using 6 layer PCBs on mid range boards.What parts do they cheap out on?
What is an SoC?you cant oc x3d chips... im refering to asus pumping the SOC voltage to a stupid number
Their GPUs also seem quite poorly made and have a lot of issues according to Northwest repair.
Build quality of Gigabyte parts has always varied widely by market region for some reason, some parts of the world they have a very poor reputation for it, in the UK we seem to get the good stuff mostly. I remember there was a shipment of their Fermi cards intended for the Middle East market that ended up here and they were pretty ropey with rattly and prematurely failing fans, parts like the sheath not sitting flush in place, connectors which had been lazily placed before soldering, etc. etc.
