New system advice
27 Aug 2004
UK
I've been asked by a relative to build a desktop that will be primarily used for work - construction management and design. A smaller form factor is preferable. The most resource intensive application will be AutoCAD. I've put together a potential system using my preferred brands; any advice on where it could be improved would be much appreciated. The budget is around £1,000.
My basket at OcUK:
Total: £894.90 (includes delivery: £0.00)​
Thanks!
Thanks, I'd not included storage as I have some spare NVMe and SATA SSDs from previous upgrades. Are there significant benefits for going with AMD?
Better upgrade potential, especially with the 13th-14th gen issues and the 9000 series have quite a bit higher single core/thread performance than 12th gen.
