Looks awesome. How long will it stay that tidy though?
I cleaned, took that photo and then put all the clutter back
, Don;t think OCUK wants to see my Tupperware box full of raw papers etc
Under the table is a crazy mess
1 plug for the huesync light on the back on my desk.
1 plug for the hue sync light on the back of my monitor.
1 plug for the hue sync hub
1 plug for the bt smarthub
1 plug for my main monitor
1 plug for my second monitor
1 plug for my pc.
1 plug for each speaker (there's no right of left speaker, each speaker is identical with its own amps inside)
So 8 power plugs total lol, then all the other cables running all over the place :O
I need to get some cable management going
Those HS7s look amazing, assume the sound quality is top notch too? - Love a bit of Yamaha - also soothers season has started for all I guess
Yea everything sounds amazing
I've been listening to genres I don't even like, just to hear how the different instruments sound and everything sounds totally authentic to me, was loving some Beethoven piano earlier
Definitely really good value and in white they look fantastic.
Crazy loud for a pc though even with the speakers gain levels at min, I'm having to limit windows volume to like 20% for just rando youtube videos or watching the football :O
Monitors though so sound amazing still at nearfield distances even though the speakers are pretty massive
I just need some stands so the tweeters are at ear height
0 hiss connected to my creative Z SE, smart hub gave interference at desk level, but as soon as I moved it higher up it went away, as you can see in the pic it's still basically sat almost touching the speaker.
