Horizon Zero Dawn
Just loading up,. it ships with DLSS and FG v 3.5.10 btw so will need to manually swap in 3.7.x and enable preset E using DLSSTweaks.
That peaked my interest. Is that something my 3080ti would support?
Really annoying that I have a conference call with the USA in ten minutes.....
So the benchmark crashes half way through, a good start!
And if it doesn’t it does when you get the report. Game is otherwise fine so far though, just trying to get hold of my old saves!
They’ve done a great job of the visuals and it’s running at not far off a locked 120fps at 4K with frame gen.
I've locked it to 100fps 4K just so the GPU can run deathly silently :D - No need to be higher this sort of game really!
Despite completing the original I don't have a new game+ option.
Is there a way to transfer saves from the old game via steam cloud?
Edit - Nevermind, found them on my old PC and transfered them over using USB stick.
Yes the benchmark crashed for me afterwards as well, but was 139 fps average on highest settings with 4K and DLSS set to Quality.
I did notice LOD pop in though :(
Yeah I still can't access those save games.
In the remaster, when you go to 'Load' you can press LB (or E) to go to 'Imported Saves' but mine just says No Horizon Zero Dawn Complete Edition saves detected.
Don't really want to have to re-download the original.
It's not working for me. It says it can't connect to the internet and that I need a Playstation account to play.
Possibly something to do with me being on Linux and using Gamescope to enable HDR...
Edit: Nope, it's not that. I'll try a reinstall
On Steam I just clicked B to skip signing into PSN, nice that this game has that option unlike a couple others.
