- 2 Jan 2012
- UK.
Attractive? No, that's weird and you should be ashamed of your kink
But there is something to be said for exhausting hot air out of the case asap, a blower/passthrough hybrid could work well, perhaps send heat from 1 or the other out of the case and have passthrough for the other.
I mean, if you're admitting you're shallow and just in it for the looks then I applaud your honestyJust to clarify, not that kind of attractive, aesthetically attractive![]()
They do have a nice, clean design when not accompanied by gaudy stickers. The noise though, I'll always associate them with the FX dust buster...
Remember buying third party heatsink for ati 1800 replacing the blower then using a couple of 12cm fans
Possibly made by artic?
This has just reminded me of this!
Arctic Accelero, I tamed a 4850 with one of those and a 140mm fan.Remember buying third party heatsink for ati 1800 replacing the blower then using a couple of 12cm fans
