- 15 Sep 2009
- Birmingham
Are vpns such as NordVPN worth it for home internet security?
Fair enough, just reading about NordVPN and the reduced price it’s on offer for and the promise of extra security etc including anti-malware protection and data breach scanner
Thanks for letting me know, sounds like typical sales talk then to try and baffle people with security threats
NordVPN has threat protection pro so actually it will help stop malware.What sort of security? They protect you from your ISP seeing what you are doing, and nothing else. It won't stop you from picking up malware from dodgy sites, and it won't stop state level actors or law enforcement finding out what you're up to.
Ditto, mullvad is my go to. If you are privacy concerned I consider mullvad the best overall solution.I'd recommend mullvad. Flat rate of £5 a month. They dknt use your email address, they provide you with a login and you can buy vouchers of amazon for added security.
What makes then better than say Private Internet Access for instance who I chose on them having been audited a number of times and tested in court.Ditto, mullvad is my go to. If you are privacy concerned I consider mullvad the best overall solution.
I would say the main thing is total anonymity and privacy. You register an account number with no other details. You can pay in cash or crypto as well as other conventional routes.What makes then better than say Private Internet Access for instance who I chose on them having been audited a number of times and tested in court.
You can do that with PIA as well though, burner email address, gift card or crypto.I would say the main thing is total anonymity and privacy. You register an account number with no other details. You can pay in cash or crypto as well as other conventional routes.
Plus having been around since 2009 so are OGs
good to hear, not looked into or heard of PIA, but sounds like it could be good for some alsoYou can do that with PIA as well though, burner email address, gift card or crypto.
Not owned by a parent company who have highly dubious other interests in the very things they claim to prevent, or employing the idiot behind Mt.Gox's implosion as CTO when his biggest claim to fame is being too stupid to know he had been robbed, multiple times. Oh and mullvad actually own the hardware, PIA have a nasty habit of renting, that's a pretty major difference as it directly impacts which legal entity is subject to any law enforcement activities/requests, they also end up on black lists quickly as they publish server details. Don't get me wrong, there are worse companies than PIA selling VPN's, but there are a lot of reasons to consider better options depending on your usage/needs, but PIA via cashback is almost for nothing per year, that's probably about right in terms of value.What makes then better than say Private Internet Access for instance who I chose on them having been audited a number of times and tested in court.
