- 20 Oct 2002
- Derby
These issues will likely be because of incorrectly fitted CPUS. The nvme slots will be related to different CPUS so if only one is working then it will likely only be working with some of the nvme slots and some of the PCIe slots.Well gues what. I think it may be nearly working now.
It was suggested by the mobo seller that it may need the BIOS updating (why, you may ask, are they being sold without the latest updates?). How do you update the bios, if you can't pass POST? Well on the Asus board there is a 3rd ethernet port for server management. They suggested hooking this up to the network , finding the IP of the port, and logging in with a web browser.
The hardest bit was finding the IP address. At first I just saw my old server, but after a bit of trial and error was able to log into the management port and run iKVM, and there was the option to update the bios. With version 2204 on the local PC it was simple to flash a copy to the mobo.
With the bios updated, it's now possible to boot into the BIOS. It's not completely working, I seem to have a couple of issues:
- seems to be only recognising 128Gb RAM
- seems to be only finding 1 processor
- After POST says it can't see the NVMe device (there are 2 NVMe's, the boot one has a clone of a WIndows10 disk on it).
Hopefully these can be sorted out tomorrow...
