Definitely recommend the Quest 2; you can play wirelessly with your PC and hook up to a socket if you need juice while you play.
Are you able to get this working with Air Link? There's something badly wrong with Elite for me in the Oculus app, it won't start using Virtual Desktop as it complains there's no headset, it will start with Air Link but then I'm told to log in via the launcher on the PC, only there is no launcher.
