MSI's support page is not very helpful because it says "latest beta BIOS" for all CPUs, but looking at other X870 boards (e.g. Gigabyte & Asus), they appear to have support for the X3D from the first BIOS release even though it doesn't officially exist.So, apologies if this sounds dumb, but a BIOS update shouldn't be required before installing this CPU, right? I have a BIOS update ready for my new MSI X870 Tomahawk Wi-Fi ready to go, and I could use BIOS Flashback, but I was planning on going the traditional route of booting into the flash tool via the UEFI.
ffs I'm starting to get the itch.
Same as what I saw. Oh well, I'll do it their way instead of mine just to 'be safe'.MSI's support page is not very helpful because it says "latest beta BIOS" for all CPUs, but looking at other X870 boards (e.g. Gigabyte & Asus), they appear to have support for the X3D from the first BIOS release even though it doesn't officially exist.
I'm kinda hoping it would maintain stock performance with fewer volts to bring the two closer in line. I'll have as many case fans as I can fit to get heat out so I can maximise GPU headroom.The temperature of the chip due to the new manufacturing is not the important part.
A 9800x3d turns more watts of electricity into heat than a 7800x3d so in a small computer case where the question is heat build up, the 9800x3d is producing more heat.
Can it be gimped to a lower wattage and still be a better performer? Maybe.
Not important to who? The people who don't care about their CPU throttling?The temperature of the chip due to the new manufacturing is not the important part.
There is no maybe. Fps/w for the 9800X3D is higher = it's a more efficient CPU.A 9800x3d turns more watts of electricity into heat than a 7800x3d so in a small computer case where the question is heat build up, the 9800x3d is producing more heat.
I love my 7900xtx but you do not want to put one in a small case. Untamed she can pull 450watts. Most of them are 3 slots aswell.Now that people are getting to grips with the review data and starting to get their hands on them, wonder if anyone can help confirm what I'm thinking.
Going to be putting this in a fractal terra (very small case) and coupling with a higher end GPU (possibly 7900xtx, tbc). So my my main criteria will be to keep heat down.
My thoughts initially were that the slight higher power draw / thermals in some reviews actually makes a case for the 7800X3D for my use case, but on second thoughts the performance per watt is actually still in favour of the 9800X3D. Assuming I can undervolt to help keep temps lower where cooling is limited I'm thinking stick with 9800X3D when I can eventually order one.
Also any thermal focused reviews anyone's spotted that I can have a look over in case I've missed them?
My only comfort is that there are a few builds on pc part picker that manage with one. Again I'd be looking for a slight undervolt if I can. 3 slots is a concern I'd already picked up on and pushing me towards a smaller CPU cooler than I'd prefer hence my original question. Still, the way the case is layed out with a vertical GPU and spine through the middle I should be able to get a decent amount of hot air straight out.I love my 7900xtx but you do not want to put one in a small case. Untamed she can pull 450watts. Most of them are 3 slots aswell.
It's already an unhappy discussion since you don't understand the simple concept of efficiency.Not important to the question of which cpu produces more heat which was the question you were replying to...
If you don't understand that the 9800x3d runs cooler AND produces more heat than a 7800x3d then this won't be a happy discussion.
Good to know thanks.YMMV, but my 7900XTX doesn’t like undervolting at all. If I go anymore than 10-15mv under volt, it gives driver timeout errors in some games randomly.
Excellent card aside from that.
You're not alone, especially comparing 2 generations ago. Anyone found any decent air coolers?ffs I'm starting to get the itch.
Get it treated mate, or it’ll spread to your belly button and eventually your armpits and ears.ffs I'm starting to get the itch.
Can't go wrong with Thermalright.You're not alone, especially comparing 2 generations ago. Anyone found any decent air coolers?
CPU Air Cooler, Dual Tower, ARGB Lighting, Black Design, 7 Heat Pipes, 3 Year Warranty
