- 18 May 2010
- London
I agree pcie5 is required if upgrading mobo today or tomorrow. Are you moving up from 5800 AM4 ?
No plans too no
So, apologies if this sounds dumb, but a BIOS update shouldn't be required before installing this CPU, right? I have a BIOS update ready for my new MSI X870 Tomahawk Wi-Fi ready to go, and I could use BIOS Flashback, but I was planning on going the traditional route of booting into the flash tool via the UEFI.
I used MSI's flash straight from USB onto the board method instead of going through M-FLASH in the UEFI and it worked perfectly. I'm up and running.For what it’s worth, I contacted Asrock on this exact issue today.
The motherboard shipped with BIOS version 3.06, which apparently works for booting a 9800X3D according to their website, but the website also only says this cpu was ‘validated’ on version 3.10. Huh.
Their support team recommended using BIOS flashback, out of the two options.
Yeah I'm sure MSI have a funky name for it too, just couldn't remember. And yes, it was almost paralysing but in the end worked a treat. Documentation isn't great - only works with FAT32 media, but at the very least my motherboard manual mentioned nothing of the sort. Only hiccup I had, fortunately.Thanks. Yes, ‘flashback’ is what Asrock call their ‘straight from USB’ option.
Good to know it worked. I think there’s just a natural, healthy fear of bricking the board![]()
I find he always has to find something to have a dig at AMD.Some comedy content where the 14900k is the better gaming cpu vs 9800x3d. User benchmark in video form.
What an absolute sausage that guy is.Some comedy content where the 14900k is the better gaming cpu vs 9800x3d. User benchmark in video form.
@Robert896r1 @PonerosHad a bit more time to play with my 9800X3D and refine my tuning, and whilst these are not going to be my best scores, they are the best I've managed so far using PBO and just today I experimented with an all core overclock.
PBO
All Core Overclock 5.7Ghz (can optimise further for sure)
I've not yet had much success with ECLK, currently PBO scores better so probably need to find the right balance of voltage, e-clock and curve optimiser settings to max out performance there.
@Poneros @Robert896r1
Further tuning, based on the silicon and cooling equipment available to me. 64155 new PB score.
The next step to improve performance further would be to bring out the portable air con unit and press it is against my 360 AIO, which I predict will add maybe a few more hundred points onto my score.
I saw Frame Chasers posted some results of the 9800X3D vs 14900KS in Riftbreaker. A game that is rather unfavourable to AMD CPUs for whatever reason.
I therefore decided to copy his settings running 'The Riftbraker' using my 24/7 tune profile, the results are below. Please note, this is not MAX Overclock.
My results were, 11% better 1% low FPS and 3% better average FPS than is 'MAX OC' results.
Just booted my MSI x870 carbon from board release BIOS and this CPU. Can't imagine the tomahawk would be any different in that regardSo, apologies if this sounds dumb, but a BIOS update shouldn't be required before installing this CPU, right? I have a BIOS update ready for my new MSI X870 Tomahawk Wi-Fi ready to go, and I could use BIOS Flashback, but I was planning on going the traditional route of booting into the flash tool via the UEFI.
