Hi guys,
Time has come round and I need to upgrade my daughters rig as it's running Win10, and the board won't do 11. This is a gaming machine but nothing massively high end, 1440p at reasonable spec should sufficce well, but I don't mind investing to get a few years from it.
I was looking at the pre built options, but as they all have see thru panels and rgb's, a solid case was the preferred option so looks like I'm building it again. Guess I'll get some better hardware for a cost saving anyway.
Budget wise somewhere around £1000-1200 I'd guess should do this nicely, if I can save some, win.
Could I get some build options please, KB & mouse not needed, but will need a copy of 11.
Case won't need an optical drive, so sizing is mmostly going to be determined by GPU?
Intel / AMD I wouldn't know which is the better for this spec range.
Many thanks for any advice you can offer.
