1440p build, solid case
18 Jun 2009
Luton
Hi guys,
Time has come round and I need to upgrade my daughters rig as it's running Win10, and the board won't do 11. This is a gaming machine but nothing massively high end, 1440p at reasonable spec should sufficce well, but I don't mind investing to get a few years from it.
I was looking at the pre built options, but as they all have see thru panels and rgb's, a solid case was the preferred option so looks like I'm building it again. Guess I'll get some better hardware for a cost saving anyway.
Budget wise somewhere around £1000-1200 I'd guess should do this nicely, if I can save some, win.
Could I get some build options please, KB & mouse not needed, but will need a copy of 11.
Case won't need an optical drive, so sizing is mmostly going to be determined by GPU?
Intel / AMD I wouldn't know which is the better for this spec range.
Many thanks for any advice you can offer.
If I could within budget, but if not no drama I wasn't expecting to
Here's a spec including monitor, but it doesn't have the OS. Are you planning to keep hold of the old PC? If not, you could try using the Windows 10 install in the new PC and then upgrade to Windows 11 if you're able to retain the activation/license.
You can still install Windows 11 without a key, but you'll have a watermark in the bottom right corner and it can't be customised (desktop background, colours, etc).
Picking a case without RGB or glass panels is tricky. I don't know how good the observatory is, so you might want to shop around. There's a b-grade Phanteks P200 which was tempting for this build, but would have needed an ITX motherboard.
My basket at OcUK:
Total: £1,217.83 (includes delivery: £7.99)​
am5 build, leaving upgrade options down the line. Not putting a screen on as ideally i would want one with 144hz or higher, unless you plug it into an oled tv where the 120hz countered by instant pixel response
if you can stretch to a 2tb ssd, even better as games are getting large...seeing as for your daughter gone for some rgb...white might be nicer also, but there's a white tax to contend with...shop around..seen the cpu cheaper or 7600x similar price with free delivery
My basket at OcUK:
Total: £1,232.92 (includes delivery: £0.00)​
Hey, thanks for the build option, but as per my post, a solid case was requested. The last build I did for here was complete custom rgb, this time she's asked for a solid case. Only just seeing now that solid cases are really not all that common. Appreciate the AMD option, gives me a good idea of what I might be looking at.
Many thanks, I can't really salvage anything from the last build tho, as it's used on a daily basis.
sorry, missed that bit
below with a pop air...bumbed up the ssd to 2tb as on offer, but can put back to 1tb and save a bit
My basket at OcUK:
Total: £1,255.84 (includes delivery: £0.00)​
you could go something lime the lian li A£ mATX case.. below. just off out..need to check clearance for air cooler..does fit an atx psu...and comes with no fans, so would need to buy some...but just an idea if you prefer the smaller look
My basket at OcUK:
  • Total: £1,240.84 (includes delivery: £0.00)
Hi,
I would actually love to do a Lian Li build as I've always held their cases in high regard, but I think this one might be a bit on the small side - will check if a 4070 will fit.
Quite suprised they don't seem to offfer any closed cases now.
Hi,
gpu max length 415mm..it'll fit a strix 4090 no problem. new case designed for bigger gpu's
Morning all,
Pay day's approaching, so thought I'd get the build in a basket to see how close I get to budget - turns out, not very lol. A few items were still on pre-order, and there's a couple of decent discounts running, so upgrading to raptor only added £20, and 6GHz ram was pretty cheap as well.
So looks like I'll end up about £400 over budget, once I factor in the cost of a copy of Win11, that does include a nice screen tho. Please take a look at the below list, see if there any easy swap outs we could make, at this budget to offer any improvements?
I'm thinking this should easily do quite well for a 5+ year rig?
My basket at OcUK:
Total: £1,535.89 (includes delivery: £0.00)​
£205 (incl. VAT)
£190 (incl. VAT)
£13 (incl. VAT)
£10 (incl. VAT)
£2 (incl. VAT)
£1 (incl. VAT)
That NVME drive is Gen5, but the motherboard takes Gen4. (pci-e 5 is for GPU only)
Swap for either of these 1TB or 2TB drives. (or both ;))
My basket at OcUK:
Total: £162.94 (includes delivery: £3.99)​
Do you need the extra fans? Case comes with 3 x 140mm fans included and should be sufficient.
I was thinking of adding the three fans up top, thinking more fans would run slower = quieter?
Cheers for the PCI info, I indeed thought it was for m2 support.
Possibly with the fans, but it might disrupt the airflow and make it less efficent.
I would try with only the supplied fans (2 in the front and 1 in the back) and use the blanking plate on the roof of the case.
If it does not cool enough, swap to the vented roof plate. If still not good enough, then think about adding fans.
Many thanks, those couple of savings will pay for a copy of 11 home.
If you have a USB Storage Drive - You can download via Microsoft a Windows 11 Installation Tools which allows you to boot from the USB Drive and Install Windows.
You can also use Windows Un-Activated losing some customisation such as Task Bar, Desktop Wallpaper etc.
But if you want an activated copy then Activations Keys can be bought online (I recently paid £9.99) but did have to activate via their automated phone call process but for 10 minutes of my time I saved a chunk of money.
Some keys depending where from will work without the phone call method.
Cheers, I'm aware of the digital version of Windows, was planning on purchasing this direct from MS tho, just to save any possible issues with authentication in the future.
