The SFF Case Gallery And Specs Thread
Hey Guys here's mine! :cool:
Form Factor: SFF
Manufacturer: ShuttleX
CPU: AMD 3400 +
RAM: 1gb OCZ Enhanced Latency
HDD(s): 80GB SATA.
GFX: Hercules 9800 pro.
Speed (if overclocked): Stock.
Temps: 66c
Pictures.
:D
Edit - Drive will be sprayed matt black in the next few days. :cool:
What a blast from the past. I loved this machine and took it back with me to South Africa when I moved there for a bit.
Actually considering a new build for a sim racing rig setup.
Xtia sent us their XSlim configurable and modular ITX case to play with. In it's compact mode 3.6L but can be expanded to 4.7L up to 5.8L for larger GPU's!
Specs here:
Intel 12700K
Asus Z690i Rog Strix motherboard
Kingston Fury Renegade 64gb DDR5 Memory
Gigabyte RTX 4060 LP Graphics Card
Enhance ENP 7660B Modular PSU
Xtia XSlim Mini ITX Case in 5.8L mode.
https://i.~ibb.co~/ZTLTjDY/MBP01569-Enhanced-NR.jpg https://i.~ibb.co~/kKzgs0Q/MBP01571-Enhanced-NR.jpg
https://i.~ibb.co~/Lz8FKKS/MBP01572-Enhanced-NR.jpg https://i.~ibb.co~/Fhc9y3h/MBP01574-Enhanced-NR.jpg
https://i.~ibb.co~/g9V6y1J/MBP01577-Enhanced-NR.jpg https://i.~ibb.co~/MGckwRw/MBP01579-Enhanced-NR.jpg
https://i.~ibb.co~/25593mH/MBP01580-Enhanced-NR.jpg https://i.~ibb.co~/G97Yv3R/MBP01583-Enhanced-NR.jpg
https://i.~ibb.co~/MGqj8C8/MBP01586-Enhanced-NR.jpg https://i.~ibb.co~/Jvn6Qtg/MBP01588-Enhanced-NR.jpg
https://i.~ibb.co~/mCKPBXS/MBP01589-Enhanced-NR.jpg
Really keep wanting to build an itx system for myself. I’m about as small as I can get with matx now.
I started off at MATX years ago back in 2012 then moved to ATX and really didn't like it so transitioned to ITX. Haven't had a ATX system in 6 or so years now, it's the best move ever if you don't mind working in confined spaces and having small hands is a plus :cry:.
my matx is just under 22l so not exactly that small but one of the smallest budget cases i could find. smaller would be better though.
The one shown above can be as small as 3.6L, it's absolutely tiny! hence why you need a decent FLEX PSU.
https://i.~ibb.co~/CtTyDR6/Capture.jpg
I've got a ZZAW C2 which is pretty small for matx at 13.9l.
Horrific for cooling, and could never hold the giant flagship GPUs, but I did like having that on the desk. C2P exists too, which is a bit more friendly, at the cost of a little extra size.
Also have an SKTC A10, which is very small, but only decent for APU builds, or low profile PCIe cards.
Complete, one for the true SFF guys!
https://i.~ibb.co~/FWhXpNv/MBP01592-Enhanced-NR.jpg https://i.~ibb.co~/3mpPFLV/MBP01594-Enhanced-NR.jpg
https://i.~ibb.co~/j4FXxSC/MBP01597-Enhanced-NR.jpg https://i.~ibb.co~/NsZwqgx/MBP01598-Enhanced-NR.jpg
https://i.~ibb.co~/L5YRmNJ/MBP01600-Enhanced-NR.jpg https://i.~ibb.co~/NLzq3Gm/MBP01602-Enhanced-NR.jpg
https://i.~ibb.co~/6w9FCrj/MBP01603-Enhanced-NR.jpg
To finish this one off, i've designed and printed off a custom front cover to hide the poke from the gpu and it's cables.
Tried to adhere to the original design somewhere.
https://i.~ibb.co~/7NRT1Y5/MBP01606-Enhanced-NR.jpg
https://i.~ibb.co~/T2Nn6LN/MBP01611-Enhanced-NR.jpg
Looks great.
I'd like to see an even small version even, without the room for the GPU.
Could quite happily go with a little APU ITX build on the desk.
the 3d files are on this website. not sure it would take all that much modifcations to sort out
