Ahh that makes more sense. I should go back to bedNo lol. A reboot and running cinebench were before and after results.
Aye, the Corsair ones are pretty crap.Just fitted a new cooler, H150i.
thats because you cant,,, it locked if you try to oc it drops to its base clocksI found any overclocking actually dropped performance as I lost the boost speed and it would run at 3200mhz. I left mine at stock in the end and got great performance.
that'll be fine.Got one of these now but awaiting the new cooler to arrive.
To check the CPU actually works etc. without putting any load on it other than BIOS and desktop with something like CPU-Z, any reason I couldn't use the current cooler briefly, which is a Wraith Spire?
Do these still allow you adjust PBO?thats because you cant,,, it locked if you try to oc it drops to its base clocks
you can chance the base clock to like 102
yes, but only a little as it affects other parts of the system tooNo.
Curve Optimiser and BCLK, thats it
I wouldn't be buying into AM4 at this point, 5700X3D is a nice Hail Mary if you are already on the platform; but makes a lot less sense to replatform onto - unless you are jonesing around for 2nd hand motherboards and have some decently clocked DDR4 to transpose. A big part of the value proposition for this is that it's just a straight CPU swap so you dont have to spend hours dicking about swapping motherboard etc. For me personally, it'll be relatively cheap to do after I flip my existing 12 core and keep me going until AM6.Wondering if I upgrade my office machine (which is basically work, simracing and zwift) from an i5 9600k to an AM4 build, can be done a lot cheaper than AM5. Chinese 5700x3d is so tempting.
I'm moving my living room rig (which is my main gaming machine these days) from AM4 to AM5. The old AM4 bits are ITX though and I don't really want to repurpose the ITX setup. Resale on it is quite good though by the looks.I wouldn't be buying into AM4 at this point, 5700X3D is a nice Hail Mary if you are already on the platform; but makes a lot less sense to replatform onto - unless you are jonesing around for 2nd hand motherboards and have some decently clocked DDR4 to transpose. A big part of the value proposition for this is that it's just a straight CPU swap so you dont have to spend hours dicking about swapping motherboard etc. For me personally, it'll be relatively cheap to do after I flip my existing 12 core and keep me going until AM6.
Hello All,
I'm after a little advise for RAM to pair with 5700X3D.
I was stuck between Corsair Vengeance 32GB 3600 CL16 or 3600 CL18?
Is it worth the price difference? Is there other RAM you could recommend?
Thanks
Sam
