- 18 May 2010
- London
This is what I have but it's currently out of stock.
I had a look earlier and personally I would go for the Team Group 8Pack RIPPED Edition 16GB (2x8GB) DDR4 PC4-28800C14 that's linked.This is what I have but it's currently out of stock.
Hello All,
I'm after a little advise for RAM to pair with 5700X3D.
I was stuck between Corsair Vengeance 32GB 3600 CL16 or 3600 CL18?
Is it worth the price difference? Is there other RAM you could recommend?
Thanks
Sam
Thank you for the replies.
Yes I do remember with 1st or 2nd Gen of Zen, they could be picky on the RAM. I wasn't sure if it was still that case.
Thanks
Sam
Thanks for sharing. By IMC I presume you mean flck? Are you using curve optimiser? I presume so due to 107W max draw.
Apologies, I worded the question wrong. I know what an imc is, why is yours subjectively good?No problem.
IMC = Integrated Memory Controller
So got my 5700x3D up and running and was straightforward.
Im a bit out of the loop with regards to PBO and curve optimiser (back in 3600 days PBO didnt make a worthwhile difference)
Ive set cure optimiser to -30 all cores - should I be enabling PBO as well to gain the benefits here?
It takes 30 seconds and is usually stable, to me thats a no brainer
No overclocks to have to worry about like non X3D chips also makes things simpler.
I'd need to read through that thread but I'm not convinced that a quick fiddle in the BIOS for potentially lower temps with better performance isn't worth it.
Stable for me means it doesn't crash when I do the things I do, so in that case mine is "stable"
From memory I ran R23/P95 and CPUZ stress at the same time to do a mini test when I got the chip, seems to recall it was a couple of degress and a few watts lower. Nothing amazing and it wasn't throttling beforehand but always nice to see those values drop.
Not overthinking it. I was just sharing some things I knew from haunting forums and my own tinkering experience.You’re seriously overthinking things.
We’re not setting a negative CO for overclocking gains, we’re simply doing so to drop power usage by a fair chunk. -30 gets the average user a good drop, along with the associated temperature drop. These chips do not need anywhere near the 105w AMD like to push through them.
