How long can an unpowered NVME hold data?
1 Sep 2003
Redcar
Considering putting an NVME I have in an enclosure and using it as backup. How long can I leave it without electricity before it loses data?
The other question is can I plug it in before x number of months/years and be good for another set of months/years or does all the data on it need to be re written?
I did a bit of goggling but the answers were mixed and years old.
It Will depend on the exact chips on the board and the capacitors on the board.
I would guesstimate it will do a year, I've had lots of USB drives last longer than that - but for anything I want assurance over I still have that on multiple hard disks personally (in fire safes and at least one off site).
Edit because I hit send before adding this: The only way to get you the correct answer will be to see if the vendor has a detailed datasheet with that parameter listed (something like a WD red or equivalent NAS type nvme might have that detail?)
Thank you. To be fair I don't mind plugging it in every 6 months or whatever the case may be. :)
I'm not aware of any reliable information about it, but from what I'm aware it depends on:
- The storage temperature.
- The type of flash technology, e.g. TLC/MLC, with newer tech like QLC less likely to retain it than older tech.
- The age of the cells (i.e. a new drive holds data better than an old drive).
- The sophistication of the ECC/recovery algorithm.
The worst case with a poor quality well-worn QLC drive at high temps was like a few weeks, but a good quality MLC drive at low temps was years.
Most solid state/NVME will retain data for at least 4-5 years without being plugged in, but it isn't a medium you want to rely on for long term data storage - in theory a lot of modern NVMEs should last a lot longer than that.
Hard to find good data on it, this one is a bit older and for SSDs but covers the bare minimum requirements for unpowered data retention:
This is why though I have my backup solution doing real time mirroring to HDDs, though using NVMEs as the frontend for performance, which I swap out periodically so I always have 2 offline copies on HDD - HDD data retention is generally around 4x that of NVME and can potentially last several to many decades if stored right.
A lot of vague stuff, i think i'd be planning for a 6 month to 1 year cycle theres nothing conclusive i can find, i imagine its not a primary role they are testing for but check the type of ssd you have as it seems MLC is the only one with a reasonable retention time.
MLC (Multi-Level Cell) Flash Memory uses a single cell to store two bits of data. The average data retention period without power is between 3 to 5 years.
TLC (Triple Level Cell) Flash memory uses a single cell to store three bits of data. The average data retention period without power is between 1 to 3 years.
QLC (Quad Level Cell) Flash memory uses a single cell to store four bits of data. This is a very complex system with huge damage to the cells within pretty short time frames. The average data retention period without power is between 1 to 2 years without power.
