Help me find a cable please!
Back of the PSU physically says type 4, manual says something about the 24pin.
By all accounts the cable just shouldn't fit if it is a type 5. I'm torn on what to do, tempted to just swap the psu out
Sooo, lemme guess that right, Corsair by email say it is type 5, in their press release they say type 4 AND the rear of the PSU says type 4?
Yikes.
Yikes.
Yeah and even on the website product page it says it's a type 5 if you follow the SKU through google "CP-9020271-UK"
By all accounts if it's not a type 5 cable it shouldn't even fit though
Clearly says type 4 on that photo
So All the cables should be interchangeable
Except possibly the 24 pin
Pretty sure i just swapped the psu
And left all my cables in place
Except for the 24 pin
When I changed 860axi to hx850i
Think that was type 3 for the axi and type 4
For the hxi
All this hassle because corsair don't make the psus
So sometimes they use a different manufacturer
Though my build uses just about every cable possible
So not a quick job to do a full rewire All the cables
If its a relatively easy build
Just do a full swap psu and cables
That way it's 100% guaranteed to be OK
Even though I think they are interchangeable other than maybe 24 pin
For the hxi
Its all the conflicting information, on their website, from the Corsair support to it not being in their compatibility table.
Then on the back of the physical unit it says type4.
Part of me thinks we'll if i had this already I probably would have just swapped them in but pre planning has made me cautious lol
Jan 2022 will be a type 4. The type 5's are very new.
I have a ton of them if you want one.
I have been buying their PSU's for years. I have a big box full of unused type 4's.
My guess is that they are saying type 5 because the type 5 PCIe are the same as the type 4. They have a chart somewhere that shows what actually changed for each type and mostly it was only one lead. That's only a guess, but anyway, go by what is on the back of the PSU.
That's nice of you to offer thanks, the new PSU arrived today and has four of the pcie cables anyway and I only need the three so the idea was to steal one in the mean time rather than swap all the PSUs in and out but was trying to work out who was right and who was wrong lol
Sorry, I should have replied earlier - I didn't see the thread. Anyway, you got it sorted and that's the important thing.
Which 1000 did you buy?
The RM1000x (2024), SKU is above somewhere, site says that it uses type5 cables but the pic i posted the back of what i got says type4 hence all the confusion, even corsair support said it was type 5.
I posted the SKUs for both PSUs involved
Type 5 won't physically fit in type 4 psu anyway
Personally I think their support is mixing up type 5
With pcie 5 hpwr cable
If its 2024 psu I would expect it to have one of those
Not just their support but the listing on their actual website is wrong too!
That's kinda what I was counting on, type 5 not fitting. I'll be able to check tomorrow
Alright just to update, I've tried one of the cables from the RM1000x and replaced one of the cables currently in the 3070. It went bang.
No I kid, it's worked fine so I'm gunna swap my XTX in now after a night shift :-)
Got there in the end up :)
Didn't hurt to be extra careful though
Expensive bits of hardware aren't something you want
To go bang
Night of gaming ahead, we'll see how it plays out but yeah we got there.
100% appreiciate any and all input from folks here, I'll update this thread again if Corsair support get back to me again.
Saved me a job of switching the new PSU in and out, can get it all nice and shiny ready for when santa says I can have my 9800x3d or whoever is deciding
