Phanteks NV5, 7 & 9 (+D30 fans)
  • Thread starter Thread starter Hostile_18
  • Start date Start date
Snagged the phantek lcd screen to go with my case, just got to figure out what's the best software to use.
Are psu extension cables required given the position of the PSU? I suspect GPU extensions are required as a minimum?
I have a WireView on my 4080 so I can use the normal cable, but you would need a longer one to use it normally.
Got a phanteks AMP 1000w with a 720mm GPU cable. With the standard PCIe cable size for PSUs being around 600mm, I'm hoping the little extra will be enough otherwise I'll just have to snag some extensions. Thanks for the swift response mate.
Next Question: What HDMI mini screens are people using to fill the gap at the top? How are you getting on with the phanteks one?
Had a play around. That's the build done for now. Waiting for 50 series to drop to complete.
Nice did you build that yourself in adia64?
That's my one.
Sort of, I used a template then edited it to suit my build spec and the stuff I wanted to show (FPS etc). The 1070 lets it down but hoping for 5080/90 when they drop depending on how much ££££.
