I didn't notice any filter when I took the lid off.The filter is different? Does yours have a filter that you’ve removed?
I think your cap has separated. That looks like the "inner half" of the screw on cap. This happened to my mum's Fiesta coolant res too. Pull that bit out.I haven't got a Mondeo on site, but this pic is from a Fiesta (which should be similar), does this look the same as yours?
If the fluid you're trying to top up is just sitting in the filter, then there's already enough in the reservoir.
No, that’s how they are (it’s not my car, just one we’ve got in the workshop), many are like this to filter out any any crap someone may pour into the reservoir.I think your cap has separated. That looks like the "inner half" of the screw on cap. This happened to my mum's Fiesta coolant res too. Pull that bit out.
Have you just linked the OP to his own threadI see you've got threads on this elsewhere as well, from Googling doesn't seem you are the first person with this issue with this car either.
Brake Fluid Level Stays Minimum Despite Top Up Attempt
Hi, I noticed recently that my Brake Fluid Level had dropped below minimum. My brake pads and discs are fine on the MOT and Service just last August. I have done roughly 2.3k miles since then. I added the Ford Original Dot 4 LV Liquid just a bit. But it didn't seem to flow into the main...www.talkford.com
Also it might be lighting, camera or my monitor but that first picture looks like the brake fluid is on the way towards needing replacing entirely - I'd consider taking it to a garage unless experienced in replacing the fluid entirely.
Do you have me on ignore or not? This is teasing me.No, that’s how they are (it’s not my car, just one we’ve got in the workshop), many are like this to filter out any any crap someone may pour into the reservoir.
Yes, that is me on Talk Ford lol. There is only one more thread over there other than the one I posted but that didn't have the information I was looking for.I see you've got threads on this elsewhere as well, from Googling doesn't seem you are the first person with this issue with this car either.
Exactly this. Hence cross post over here. I will drive this evening and see if that makes any difference and report back. If it doesn't help then to garage for fixing whatever needs fixing/replacement and then report back.I can find a few threads on it for that car but they all basically have people saying "must be a leak in your brake system" and original thread starter never updates.
It's the second part about googling that made it sound like you were posting one of the other places it's been mentionedI literally said in my post:
"I see you've got threads on this elsewhere as well"
I linked to it in case it was useful for other posters to see what was being commented on there as well.
I tried this method this morning with my mobile flashlight and the level is ok. Thanks a ton for this.Just top it up to the max level, and if you're not sure or can't see it properly, hold a torch behind the reservoir, like..
