Hallway cupboard, how high would you put the clothes rail?
29 Jul 2004
Esher
Now this will sound pretty stupid but I'm having a cupboard built in my hallway, simple place to store shoes and coats.
How high would you put the clothes rail? I'm fairly tall (198cm) so if I put it at a height that is comfortable for me it won't be comfortable for pretty much everyone else. I'm thinking around 180cm (5ft 9ish) from the ground
What would others say? Maybe higher?
I wouldn't go higher than 180cm - think of short people reaching to put a hanger on it. I guess I often hang stuff in doorframes and those are higher than 180. If in doubt, get the shortest person in the household to test it. Same with mirrors, do a dry run.
However it's your home and should be suited to you/its occupants. I always build my carpentry workbench quite a bit taller than standard to avoid a bad back.
What is the longest coat you have that you will store in there? Does the Mrs or any of your high class 6ft tall escorts wear full length cheetah fur coats? Wouldn't want that draped over your minging wellington boots on the floor?
If it was something that only I would use like a workbench then agreed I'd do it for just myself but unfortunately this will have to be for the common man.
Fortunately I live alone at the moment, but that could change so want to make things a bit easier for people if/when they move in. 1.8m would be enough for my giant pimp coat and the idea is to have a small shelf to one side so that shorter coats can fit in as well.
There is going to be a shoe drawer on the side of this cabinet so that'll take care of shoes and boots.
The height of your longest coat, plus coat hanger & the height of the shoe rack (with shoes on it) is the correct answer.
It that's too high for the shorter people that need to use it, then you'll have to compromise and fit the clothes rail as high as you can get away with.
Pull down clothes rails?
Also surprised that there don't seem to be anything available for mirrors - it's a niche that needs addressing.
Only needs to be a couple of slim sliding brackets of some description
Another random thought... If it's for clothes storage make sure there's some sort of ventilation grille or something... You don't want humidity raising in the cupboard and stuff getting damp, particularly if the rear of the cupboard is an exterior wall.
