Lightspeed Broadband & Unifi URM
24 Dec 2024
United Kingdom
Hi everyone,
I'm adding a Lightspeed broadband connection (in the UK) to my existing UniFi system and running into some DHCP configuration challenges. Lightspeed provided IPv6 details but the IPv4 information they gave me includes DHCPv4 Option 80, which isn't available in UniFi's settings.
What I need to know:
  1. Has anyone successfully set up Lightspeed in bridge mode with their UniFi system?
  2. What DHCP settings did you use, particularly for IPv4?
  3. Were any specific UniFi configurations needed to get it working properly?
Current situation:
  • IPv6 is configured correctly based on Lightspeed's provided information
  • IPv4 isn't working due to the DHCPv4 Option 80 requirement
  • Trying to run in bridge mode
  • I have reverted to the standard router mode for the holidays just so the family all has internet :)
If you've got Lightspeed working with UniFi, I'd really appreciate details on your configuration settings.
Thanks!
Sivivatu
Unfortunately in the DCHPv4 drop-down menu 80 is not an option at all. It has a fixed list of about 6 different choices.
Is there a way to override the fixed list and select your own option?
Under IPv4, click DHCPv4, it’ll list options and under the option 80 populate whatever data you need in the correct format. See here: https://community.ui.com/questions/...8#answer/1337f9b6-7a91-4077-8e48-35d751c09a30
Where'd you learn that Option 80 is necessary? Specification for DHCP options suggests that Option 80 takes zero length parameter (empty) and is for "Rapid Commit," which allows a DHCP client to request and receive an IP address and configuration from a server in a faster, two-message exchange instead of the standard four-message process.
So it any client identification/authentication would not be possible via Option 80.
I'm getting Lightspeed soon, and looking to get setup quickly on my Unifi device. I stumbled upon this post. :)
If you got it working, what option did you use?
Ref per spec;
Ref per spec;
Specifications and the real world are not the same thing. If you read my post, you'll see I didn't state option 80 was required, I answered a post asking how to specify option 80 parameters, the best known example of them being used would be Sky, who inherited the use of DHCP option 60/61 for auth from it's Easynet buyout in 2005, in short they are a thing and are used by literally millions of Sky broadband customers every day.
Avalon, fair point, specs vs. real world can differ. My mistake in saying you claimed Option 80 was a Lightspeed requirement. I was more just questioning their (Lightspeed's) supposed need for it, given Option 80 is Rapid Commit and takes no auth data. Sky uses options for auth, sure, but typically things like Option 60/61 for the actual client ID strings, not 80 itself.
@Sivivatu When Lightspeed mentioned Option 80, did they give you an actual value or string to send with it? Or just say "you need Option 80"?
If they gave you an auth string (like a username/password or modem ID), it's far more likely it's meant for Option 60/61.
Still trying to get a clear picture for my own Lightspeed setup soon.
I'm going with the assumption that Option 80 was a typo for Option 60, because it seems almost nonsensical to use 80 for this usage. I could be wrong, that's what I'm trying to learn here though :D
Ref Sky's Option 61 usage - more so conforming to spec;
I don't use Unifi but OPNsense with my Lightspeed connection. Using nothing other than DHCP for connection.
Thanks for replying.
Did you get the ONT + Router (separate devices) or ONT & Router (all-in-one) configuration from Lightspeed in bridged mode?
To clarify, if the ONT (Standalone) + OPNsense, do you pass no client option through for DHCPv4?
As for IPv6, do you have that configured? If so, what prefix is advertised?
Cheers!
Cheers!
I have the Nokia ONT + Router combo. It's in bridge mode.
My config below.
Ahh okay, my understanding for new customers get a dedicated ONT and a dedicated router.
Meaning this setup likely won't work for me as I'd like to go Unifi GW -> ONT rather than having their bridged modem/router in the way. :(
For anyone else switching to LightSpeed and happens to come across this post on Google, or whatever... These are the directives I received from LightSpeed support, which worked on my setup...
Using Unifi Cloud Gateway Fibre.
LightSpeed Assigned Static IP Address.
Code:
VLAN: 911
IPv4 Config: DHCPv4 (No Client Options)
IPv6 Config: DHCPv6 (/56 Prefix Delegation)
The UCG Fibre is connected directly to the ONT. In my case, it's the Adtran one. The provided Adtran router is not used in this configuration.
Im coming back to this situation after just connecting it without setting the router to bridge mode and it working. Now its just suddently stopped working and my unifi UDR keeps disconnecting from the router (its hard wired) Looking at the settings @Ayymoss provided, was the vlan unique to you or is that a global vlan? When i look at my nokia ONT it seems to have a reference to a vlan of 1081
Best to ask them directly. It took a bit because I needed to get through their first-line support. I can't say for certain whether VLAN 911 was specific to me or not. However, just to emphasise, I pay for a static IP address. Maybe that's a factor.
You can try my configuration and see if that works, but if not, I'd just ask them or email them [email protected]
However, that configuration noted above works fine for me still today.
Awesome thanks, Ill see if any of those combinations work but its not promising for me currently. Will have to keep trying
I’ve got lightspeed working on my UCG-F and I had it working on my USG3 before.
However I have the Nokia ONT and router combo which is in bridge mode rather than the dedicated ONT set up.
I can post my config later if needed.
I also have the Nokia setup and while I now seem to have a connection (haven't used the VLAN setting suggested by @Ayymoss) but I seem to get frequent disconnects and internet dropouts. I'm not sure what the best way to identify the cause of the dropouts would be though.
I’ve had a few disconnects over the last couple of weeks but not many, they are usually in the middle of the night so I assume they are maintenance related.
We had a full outage at the lightspeed end for a few hours on 25/8 which may be related.
Yeah, mine has been stable since install, other than maintenance periods which they usually send me a text for. It has been golden.
For the VLAN for you, maybe check with Lightspeed customer support, there may be a specific configured needed for you. That VLAN ID tag was given by them for me. Not sure if it's specific to me or because I have a static IP alloc.
The VLAN tag is also set in the Nokia control panel.
I will have to chase up what the correct vlan tag is then. when i copy the one from the control panel to the UDR it just doesnt work at all. The disconnects are far more frequent and make the network completely unusable (every 5mins or so).
I'm currently having to connect directly to the nokia wifi, but it means the rest of my network (home lab, smart home etc) dont work properly any more
