makes me not wanna fly in December.
Wonder when it was last serviced.
I'm flying out at 7pm.......wish me luck!
can I have your stuff?I'm flying out at 7pm.......wish me luck!
We would have to bend the laws of physics for that to be practical at civilian airports.Wonder if you could install a big net to at least slow a plane down at the end, kind of like the emergency ones on carriers.?
Bird strike whilst taking off?
Watched it skidding along the end of the runway, but why oh why have giant walls bang at the end!!?
There are systems that act like gravel traps for planes that are over running the runway - usually found where over running would lead to the aircraft going over a cliff or embankment. Not sure this type of system is effective on a plane which is sliding on its belly though.Wonder if you could install a big net to at least slow a plane down at the end, kind of like the emergency ones on carriers.?
I do wonder if the crew were just overcome by the other emergancies and just forgot the undercarriage.
They forgot the flaps and slats too. It's looking (potentially) like a bit of a pilot boo-boo here. A single engine failure does not stop all the hydraulics for flaps and gear. Even if they lost all hydraulics, you can do a mavity-drop of the gear. Hopefully the black boxes will tell us everything.There are systems that act like gravel traps for planes that are over running the runway - usually found where over running would lead to the aircraft going over a cliff or embankment. Not sure this type of system is effective on a plane which is sliding on its belly though.
I’m not sure of the exact circumstances here but most likely the aircraft should have been yelling ´TOO LOW, GEAR´ to remind them.I do wonder if the crew were just overcome by the other emergancies and just forgot the undercarriage.
and the co-pilot didn't catch it either?They forgot the flaps and slats too. It's looking (potentially) like a bit of a pilot boo-boo here. A single engine failure does not stop all the hydraulics for flaps and gear. Even if they lost all hydraulics, you can do a mavity-drop of the gear. Hopefully the black boxes will tell us everything.
Does look like the thrust reverse was active though.They forgot the flaps and slats too. It's looking (potentially) like a bit of a pilot boo-boo here. A single engine failure does not stop all the hydraulics for flaps and gear. Even if they lost all hydraulics, you can do a mavity-drop of the gear. Hopefully the black boxes will tell us everything.
I would think so, your brain can screen out noise though when you are overwhemed with other tasks.I’m not sure of the exact circumstances here but most likely the aircraft should have been yelling ´TOO LOW, GEAR´ to remind them.
Landing after the flight wasn't it?Bird strike whilst taking off?
The hydraulics on the aircraft are usually operated in normal mode by the engines or by electric pumps powered by the engines. I'm not sure but I suspect the landing gear gets a lower priority on the available hydraulics than the flight surfaces.I’m struggling to see how a bird strike causes the landing gear to appear to fail completely.
