- 19 Sep 2022
- Pyongyang
the speed only determines the connection bandwidth between the gpu core and vram..If the speed is faster would it not negate the need to store the data in the first place "just in case". So it just gets what it needs, when it needs it? So you wouldn't need 16gb+ at any one time?
I don't know I may be massively off the mark. It's a tough pill to swallow that Nvidia deliberately holds it back..Still it's hard to deny most of us would rather have last Gen vram, but in greater quantities. Its probably less for gaming reasons though and more not to cut into their workstation cards. Gaming is collateral damage.
vram still loads data at a rate limited to the pci-e capacity
also, a miss on vram is very expensive to the tune of many gpu core clock cycles like may be 10 easily
