NVIDIA RTX 50 SERIES - Technical/General Discussion
Boring day today
people were saying its got to be hard launch given the big delay.. and nvidia hasnt set up the store page (with notify me button)
edit: remember it being up during the rtx 40 launch event
But they basically have though, haven’t they?
Looking at the leaked 5080 specs, you’re basically getting half a 5090 for 85% of the cost of the 5090.
The 5080 feels to me like it should be the 5070ti and nvidia will then pee off all those people who purchased a 5080 at launch by releasing a 5080 ti/super later on with more VRAM and cuda cores.
In 2026 by which time you're 12 months out from RTX 6000 Extra Super AI advanced neural rendering DLSS 5 FG2 8k ready
So nothings changed from current gen, so that's good. Same connection and same max power draw. 4090 and 5090 have the same theoretical max power draw of 600w as limited by the nvidia bios, and both use a single 12 pin hwpr cable
You're a braver man than me after the cable mod fiasco lol.
I've been using Corsair's 12VHPWR cable for 2 years with no issues. This looks like the same thing just with a right angle connector.
As far as I'm aware, the cablemod things that exploded were their 180° bridge things, probably wouldn't be brave enough to use Corsair's version of that :p
Besides, didn't the revision to the connector on the newer cards fix all that?
I've been using the same EVGA Supernova 1000w for eight years now. Extraordinarily solid PSU.
Since it's too old to have a 12VHPWR connector, I used a 4-to-1 12VHPWr adapter with my 4090 -- works great.
I'm honestly not sure. The revision also got recalled on the cablemod side. I just wouldn't like to give anyone an excuse to deny warranty, or be caught between two companies blaming each other, with these cards being so expensive.
i'm confused...5090 is more power hungry than 4090, and still one power connector...bit dumb don't you agree?
It's within spec, it was only ever the seating of the cable that was the issue. Plus very few people have 2 of those new connectors PSU side.
It will be like the 4090 where it almost never uses its top rating. I under volt mine and over clock to get better than stock performance at considerable less power use.
Nvidia revised the actual socket on the cards and made the sense pins smaller so it won't even try to pull any power if the connector isn't fully inserted. As far as I'm aware there's been no cases of that new 12V-2x6 connector melting, and that's what'll be on the new cards.
