Caporegime
- 13 May 2003
- Warwickshire
Hi all
I made a booboo in my current bathroom project. I need to hang a double sink wall-hung vanity unit on the wall and although I did put wooden battens behind the wall to mount it onto, I miscalculated and the wood is too low for the required bracket height, meaning I only have tiles + plugs to mount into. This is insufficient as the weight of the unit + sink is already pulling the unit away from the wall slightly.
This is a major **** up but my options to fix it appear to be:
1. Remove tile(s) and install wood at the correct location. Highly undesirable as everything has been grouted.
2. Use plugs in the tiles and liberally apply OB1 / other construction adhesive to the brackets, vanity, and sink, and hope this is enough to bond it to the tiles.
WWYD?
WWYD?
