TDRL: Actual rasterization improvement over 4-series will be paltry, possibly the worst generation uptick ever.
This is a fantastic video, best I've seen on the 5000 series. An excellent analysis.
I did think about that last night after my last post, nothing coming out before 2027/2028 seems to paint a picture of a need for a GPU higher than a 4090, and I know for sure that come those years I will be on a 40" or greater ultrawide OLED pushing at least 240Hz and 5120x2160. Perhaps doing what I originally intended by skipping 50 series entirely is the wiser option and going 60 series when those games are out.
Depends what you play. I lean towards online shooters so max raster performance is what I would benefit more from. Having said that, I have held off playing CP2077 with path tracing, so maybe a 5090 will allow me to do so at more than 60fps with DLSS performance, or frame gen at 100ish. All comes down to 5090 FE availability for me.I think RT performance matters at least as much as raster.
When do you need more performance? When activating RT/PT. We've been able to max out regular games for a long time.
And here I am writing off the 5090 because of my worry my HX1000i won't manage a 7800X3D and 5090 :OFair play, no judgement from me!
Speaking of PSUs, i’m hoping my trusty RM850x can power a 9800X3D and 5090. Should be ok if the 5090 is as efficient as the 4090 and I can run it at 80% or so. I will at least try it before upgrading.
I was also teetering on upgrading my EVGA 1000w (also using a 7800x3d) when I was looking at a 5090 but fugured a) it should sitll work and b) you should just try it, and if there's a problem undervolt for a few days while you're waiting for a new one. No sense in pre-emptively spending money (and having to spend time rewiring) when you don't know you need to.And here I am writing off the 5090 because of my worry my HX1000i won't manage a 7800X3D and 5090 :O
Good idea, but I'm trying to talk myself out of buying a 5090 either way lol, 5080 will be enoughI was also teetering on upgrading my EVGA 1000w (also using a 7800x3d) when I was looking at a 5090 but fugured a) it should sitll work and b) you should just try it, and if there's a problem undervolt for a few days while you're waiting for a new one. No sense in pre-emptively spending money (and having to spend time rewiring) when you don't know you need to.
We can max out RT/PT right now as it is, with the DLSS upgrades coming to all RTX, that will only make the IQ better and fps higher still. There's a reason why Nvidia is releasing DLSS4 on RTX50 first, then unlocking it to the previous gens, otherwise more people would not bother once they see the uplift on the 40 series from just the DLSS4 updates.
There's a time for everything, the time for a 4090 to a 5090 isn't now, it is when 60 series is out as mentioned above, when power draw is matured to sensible levels too which should be the case with 60 as new fab process so more efficient, less heat, lower draw.
