Annoyingly i've still not fitted the Redshift seatpost. Had planned to do it yesterday when i was recceing the 100km route of the Iron Gravel. However decided it wasn't sensible to try out something which needs various bits of adjusting on a longish and demanding ride.
Set off and for 30km i was cursing myself for turning my mtb into a gravel bike as the terrain was beautiful. Mix of road and some light gravel which would've been easy on my road bike with wider tyres. However i then got past a town in the mountains and hit a section where i had to carry the bike for around 2km, and even then there were lots of sections where my confidence over very rocky terrain isn't good enough so i had to keep stopping and walking sections. Absolutely no chance i'd have wanted my road bike on these bits. Although would've been nicer for carrying since it's around half the weight!
Fell off twice. Luckily once was over the handbars and into a bush which cushioned the fall (albeit causing lots of scratches as it was thorny
). I then got superbly lucky where my front tyre just about stopped right on the edge of a 3ft drop where i think i'd have definitely broken something. Was starting to lose the light a little too which caused a bit of stress but luckily got back to the car without too much fuss.
One thing i've been thinking about. Is there any issue with regular swapping of a seatpost between bikes? The Redshift post will likely live on my mtb/gravel bike. However it'd be nice to also use it on longer road rides. I have a shim to switch between 27.2 and 31.6mm seat tubes so no issues there. Just not sure if there's a lot of stress on the clamps?
). I then got superbly lucky where my front tyre just about stopped right on the edge of a 3ft drop where i think i'd have definitely broken something. Was starting to lose the light a little too which caused a bit of stress but luckily got back to the car without too much fuss.One thing i've been thinking about. Is there any issue with regular swapping of a seatpost between bikes? The Redshift post will likely live on my mtb/gravel bike. However it'd be nice to also use it on longer road rides. I have a shim to switch between 27.2 and 31.6mm seat tubes so no issues there. Just not sure if there's a lot of stress on the clamps?
