They look like the LIAN LI UNI TL LCD ones@JustHappy - that is a tidy looking system. What fans are they?
Thanks mate! They are the Lian Li TL LCD fans. I've got 140mm reverse fans for intake and because of my case, 120mm fans (x2) for exhaust.@JustHappy - that is a tidy looking system. What fans are they?
Thank you - £45 per fan - Jesus!They look like the LIAN LI UNI TL LCD ones
I know. Haha!Thank you - £45 per fan - Jesus!
Someone spending £5-10 per fan wouldn't buy an Astral card would they!!! Rather them than me.Thank you - £45 per fan - Jesus!
Hahaha, true. I remember being slightly outraged at spending ~£25 per fan in a previous build. Those Lian Li look so nice though - making me want to do a case/cooling upgrade......Someone spending £5-10 per fan wouldn't buy an Astral card would they!!! Rather them than me.
The build quality on the Astral is the best I have seen, bar none but it is also the loudest GPU I have ever come in contact with. Apparently, Asus will be adjusting the fan curve via an update.
I'm very glad I hate RGB of any kind (and have my PC under my desk). Saves me lots of money that I can spend on actual hardware which makes a difference to my frame ratesHahaha, true. I remember being slightly outraged at spending ~£25 per fan in a previous build. Those Lian Li look so nice though - making me want to do a case/cooling upgrade......
You've got a point. LolLook on the bright side if you can hear it at least you know working
A couple of times I had to get a torch out to see if the fans are spinning or stopped on my strix 4090![]()
Have MSI managed to improve the shocking memory temps with their FE design? Curious.
Where can i buy these magical stickersYes, the stickers / cut-outs apparently shave off 10-15 degrees by virtue of Panini’s advancements in technology
Where can i buy these magical stickers![]()
No point coming on these forums anymore as you have no time for pc gaming and clearly can't afford the new generation of gpu's so whats the point of mocking people for buying them.Troll and belittle? I think your completely missing my point.
I'm an enthusiast, a hobbyist of PC gaming and have been for longer than I care to remember.
I recall fondly the times when you could bag a high end card for a few hundred quid, even allowing for inflation the equation today is vastly off.
You imply my life isn't fulfilled, in actuality, my life is extremely full, so much so, I have no time for PC gaming (arguably why I still have my 1080ti) there's so many other things that I barely find the time to do before gaming even comes into the equation.
If I was to think about it , I'd probably conclude my life was by far less fulfilled when it was consumed by frame rates , gaming time etc as it indeed once was.
Trolling? Nah,I wouldn't see it as that, an admission of reality. Well...,
Yes they ship from the factory with a special DragonUndervolt™ that reins in Lucky's fire and cuts out most of the coil whine.Have MSI managed to improve the shocking memory temps with their FE design? Curious.
I'm sold! If only there was more than one in existence. In all seriousness, how are the GPU and memory temps whilst gaming, and is coil whine particularly piercing on yours?Yes they ship from the factory with a special DragonUndervolt™ that reins in Lucky's fire and cuts out most of the coil whine.
With the power limit/OC I've got set up it tops out around 70C on the GPU and 86C on the memory. Pulls ~435W total board power and comes within 1-2fps of stock in Cyberpunk/Wukong benchmarks.I'm sold! If only there was more than one in existence. In all seriousness, how are the GPU and memory temps whilst gaming, and is coil whine particularly piercing on yours?
