- 20 Oct 2002
- Oxfordshire / Bucks
thanks Rav, i may not need it, i think i may have figured out what it is (with the help of another member) so ill be testing tonight
thanks Rav, i may not need it, i think i may have figured out what it is (with the help of another member) so ill be testing tonight![]()
I got the Elite strap as it was bundled, but it's too big for my 7 year old daughters head. Do you guys have any suggestions?
What is everyone using for their controller battery setup? I have some rechargeables but they lose charge in there at about 6% / day even when not in use - is there an ideal solution out there that doesn't require disposables
I've been using some eneloop type batteries but they were pretty cheap PowerOwl ones.Thr ikea ones are supposed to be rebranded eneloops, also turn down/off the haptics and they last for ages.
looked at them, look basically the same as what i have currently@ShiWarrior
have a check of the :
AMVR Controller Grips Compatible with Meta Quest 3S / Quest 3, Silicone Accessories Non-Slip Handle Cover, Adjustable Soft Hand Strap Fits Small and Medium Hands (Not Fit Official Charging Dock)
aswell similar thing more reviews
I use these.
Maecker vr Controller Straps for Quest 3S Controller Grips for Quest 3 Controller Grips with Battery Door Anti-Slip Knuckle Straps for Quest 3S/3 Accessories: Amazon.co.uk: PC & Video Games
Maecker vr Controller Straps for Quest 3S Controller Grips for Quest 3 Controller Grips with Battery Door Anti-Slip Knuckle Straps for Quest 3S/3 Accessories: Amazon.co.uk: PC & Video Gameswww.amazon.co.uk
that's what i have now![]()
Yeah, this is exactly what I was thinking about the last few posts.I've never used controller grips, I don't seem to have any issues where this is concerned tbh. Mind you I said that about aftermarket headstraps, thought I was fine without them, then tried 1 and wondered why I hadn't done it ages ago.
