Spec me an AIO - p400a case - 9800x3d
18 May 2010
London
Guys, I know diddly squat about aio coolers.
The story is I am thinking of upgrading to a 9800x3d and wondering if it is finally time to move away from air coolers and get an aio.
I have a Phanteks p400a case.
I read online conflicting things. Some say the p400a cant fit an aio on the other hand I have seen pictures of people with the p400a and an aio mounted.
What does 240 and 360 mean? Is that the size of the radiator, ie 3 fans vs 2 fans?
Any one recommend a decent aio that will fit in my p400a for a 9800x3d?
I was thinking it would need to be mounted on the top of the case.
On the other hand should I just keep it simple and stick with an air cooler?
240 is effectively equal to 2x120mm fan mounts.
280 would be 2x140mm fan mounts.
360 is 3x120mm fan mounts.
Yes, I'd just get a peerless assassin/phantom spirit or a freezer 36 (may have to tweak the fan curve for best results), since the 9800X3D is not a high power draw CPU.
If you do want an aio for the top of that case just make sure the radiator is 27mm and 25 mm for the fan don't get the arctic freezer 3 it's radiator is to thick.
I've heard good things about the peerless assassin/phantom spirit.
I normally buy Noctua but the price is double that of the Thermaltake cooler.
According to this I can request a AM4 mounting kit from Noctua for my D14.
Get the mounting kit if you already have the d14 no point in spending it's certainly good enough.
Question.... the mounting kit says its for AM4 and AM5.
If I already have my cooler and all the parts does that mean it is compatible with AM5?
Says here:
All coolers compatible with AM4 are also compatible with AM5, as the mounting system hasn't changed in that regard.
So it seems I don't even need a mounting kit.
Wow... I know Noctua is expensive, but not only do you get top tier performance but you get some serious longevity as well.
I bought my NH-D14 with my 3570k around 2012 and it looks like in 2025 I am about to use it with another new CPU.
I used the peerless assassin for a couple of days on my 9800X3D whilst waiting for a Thermaltake frozen vision to arrive, and it was fine.
In fact, it’s surplus to requirements now, so if you want one just pay the postage and I’ll send it to you (I’ve no use for it).
I used to have one back in the day as well.
Since then i have spent a small fortune on cooling, swapping back and forth between water and air cooling.
That's a great offer mate thanks. I think though it seems I can reuse my Noctua.
Did you find a home for your cooler? :)
I'm also trying to decide if I should go with an aio or sit tight with air for a 9800x3d build, mine will be in lian li lancool 215 case.
Had a artic freezer 2 420mm in the from of my evolv x with no problem, I'm sure your case is a similar layout.
I’ve had a 280mm Freezer II in the front of my P400A for the past 5 years. Fits fine.
But that’s currently with a 320mm long graphics card. Any longer than that and you wouldn’t be able to put the pipes at the bottom.
There is no need for an AIO with a 9800x3d. A tower cooler will be fine and quieter.
this but also not this.
as said the 9800x3d doesn't need a AIO to run cool, but a well set up AIO will run quieter than an air cooler.
the Freezer II and Freezer III coolers are fantastic
In my personally experience, that’s not true for typical gaming. More fans up against a radiator or case edge as per an AIO = more ‘air movement / droning noise’. If you set AIO fans too low, it isn’t pushing air through the radiator and then the liquid ends up >40 degrees.
My NH-D15 runs at about 500-700rpm in gaming scenarios and is silent or imperceivable whilst at around 60-70 degrees. Fans don’t need to be louder because there is no need for the chip to be cooler.
There is no quieter setting than ‘I can’t hear it’ :p
If you have a very very hot CPU / threadripper etc this is perhaps when the AIO becomes worth it, sure. Otherwise I’m honestly not sure it is ‘better’ in any meaningful way.
