I've been thinking about changing my mouse, as I want USB C charging. From what you say, I assume you recommend this mouse?
How is the mouse wheel? I really like on my G903 I can swap between clicky and scrolly. Most times it's scolly, I can spin it to move up and down a webpage for example, but every not and then I have a game where wheel up and down do something and I need more control, so I can make it click through the scroll. I have another smaller Logitech which is like a hybrid, it's clicky until I spin hard, then it spins. I guess this is okay if it's how the Superlight 2 works? Ta.
I really like how everything is going to USB-C and I think you will find most Wireless Mice now use this connection type.
My previous long term main was the original Logitech G Pro Wireless (80Grams in Weight) I really enjoyed using this mouse, performed well and had no issues over the number of years I used it but ultimately after lots of "Hype" surrounding new E Sport targeted Mice I just felt like a change so since August I have tried the following mice (All of which use USB C)
- Lamzu Thorn
- Pulsar Xlite V3
- Glorious Model D Pro
- Razer Deathadder V3 Hyperspeed
Despite the above list being top tier mice, once the newness placebo effect wore off I felt like my aim in games was "Off"
In terms of it's Scroll wheel - It is "Tactile" but only very subtle, so when scrolling webpages you have to scroll slowly to feel the feint individual notches but if you speed up it then "Spins" and you can't track the notches. (Hopefully this makes sense) to engage Scroll Click it seems quite firm/stiff. I know I mentioned in the original post my DAV3 HS has scroll wheel issues (Which it does) but I have had two copies and my original copy was faultless and the Scroll Wheel was better than Logitech's, very tactile and notchy.
I absolutely love their new "Lightforce Hybrid Switches" they combine optical speed and reliability but give you that mechanical feel, finding them extremely satisfying to use when tapping in game.
Could be worth using the popular online retailer with a very generous free returns policy, in my experience returning opened and tested mice yet full refunds being received before the item has even reached them.
Edit: Forgot to mention the Mouse Skates - They aren't well received/well reviewed since they are "Scratchy" and are less "Slick" than it's competition but I actually like this, finding it gives me more control and stability when aiming rather than it feeling like a game of air hockey
