We've had MMOs bricking the 30 series cards before so I wouldn't be too quick to jump to that conclusion (New World in 2021 bricking cards with "suboptimal" soldering)But those are all software issues resolved by rolling back driver. How would a driver damage physical hardware.
Seems the melting cable thing has started with the 5090 now as well.
Im happy to be proven wrong but I just cant see how a driver is bricking a card. Causing issues within OS yes....but bricking to the point its not even detected at boot? Even if the driver was applying a MAD overclock the hardware wouldn't let you fry the card.
Perhaps the driver is exposing a hardware weakness?
It's purely coincidental?
Surely the driver would need to be making firmware updates/changes for this to occur?
nVidia firmware wont let you kill the card with voltage. You need a flashed and modified bios to do this.Yeah I'm thinking the same. Unless the driver as you said does a stupid vcore voltage overclock or something. But it's not like the driver can instruct the vcore to be 12v, so what is the actual maximum in the hardware if you deliberately wanted to fry it?
Im happy to be proven wrong but I just cant see how a driver is bricking a card. Causing issues within OS yes....but bricking to the point its not even detected at boot? Even if the driver was applying a MAD overclock the hardware wouldn't let you fry the card.![]()
^We've had MMOs bricking the 30 series cards before so I wouldn't be too quick to jump to that conclusion (New World in 2021 bricking cards with "suboptimal" soldering)
Variable refresh rate (e.g. Gsync/Freesync)What is VRR ?
No, the hardware was faulty. A game cannot kill a GPU.Wasn't that Amazon game killing GPUs not too long ago.
NV pulled the 690 launch driver, it killed a few 690s back in the day.Wasn't that Amazon game killing GPUs not too long ago.
GeForce RTX 5090 Founders Edition card suffers melted connector after user uses third-party cable - VideoCardz.com
First reported case of burned RTX 5090 FE power connector, 3rd party cable likely to blame Users should use official adapters or native power supply cables. RTX 5090 Founders Edition with melted connector, Source: ivan6953/Reddit Reddit user ivan6953 has shared images of an RTX 5090 Founders...videocardz.com
