- 2 Feb 2009
hope that helps..
Yeah, that helps![]()
hope that helps..
. Honestly it's more effort to send it back than to flash stock openwrt and set it up, both are super easy. Your talking like it's some big mysterious complicated thing, it's really not, no need to use any third openwrt fork (Pesa) either. Just get the sysupgrade image and flash it from the stock firmware settings page. You've clearly made your mind up though so good luck to you.I've just called it a day and it's going back to Amazon.
In reality i'd love to dig into OpenWRT and figure out how to use, best setups etc (Pesa's builds!), but at the same time I just need stability and reliability from the get go and it's not giving me that.
The coverage/signal is incredible, to have that and not need an extender/Access Point elsewhere was great.
Are you still on stock firmware? It's based of an ancient OpenWRT and isn't fully open source. Who knows what they are doing under there or if they have even bothered back porting any security fixes. Slap native OpenWRT on it and report any issues on the OpenWRT forum, that's the best way to get stuff resolved and help the project improve. I'm on 23.05.5 and don't have any Wifi issues. Going to switch to the newly released v24 when it's been out a while.
Basicly yes, everything you need to know is on this dedicated Flint 2 wiki page https://openwrt.org/toh/gl.inet/gl-mt6000Is flashing to OpenWRT as simple as flashing the correct sysupgrade.bin from the OpenWRT site? That seems to be what the readme file is saying, but I thought it best to check?
I've had a Flint 2 for 3 months now (running stock 4.7 firmware) and I have been very impressed with it
Thanks for that, I've not had a single issue with my Flint 2 using the stock (4.7) firmware, so I will leave it as it is for now and see how long it will be for the latest features to get added to the official firmware.Basicly yes, everything you need to know is on this dedicated Flint 2 wiki page https://openwrt.org/toh/gl.inet/gl-mt6000
If your not seeing any issues with the stock firmware and are happy with the closed source nature of it I'd be tempted to stick with it. You can always roll back to is easily and quickly though just have a copy of the stock firmware and your settings to hand.
I've been using 2x MT-6000 since around April last year.
From June I've exclusively used the Pesa builds, which I've been very happy with, as the GL.Inet firmware always seemed to miss a trick somewhere, although the GUI is lovely.
I'm still currently using the 29/12/2024 4.4.6 Pesa build and it is blindingly quick WiFi with flash and forget stability. The builds subsequent to that are more "experimental" and imo are not as rock solid as 4.4.6.
I have a wide variety of devices connecting to the WiFi of these devices (including using it for VR and working from home myself, then with a family of 4 with a mix of all manner of devices). I have no complaints.
Also, I've only setup Openwrt once per device since moving to Pesa, and just tick a box to move between versions (obviously, I backup to file if I want to try Vanilla OpenWRT or GL.inet official). It's no hardship.
Edit. As one user remarked in the Pesa thread on the OpenWRT forum "The WiFi alone is like night & day compared to stock 23.05.5. I've done 1 week on/off with each and the Pesa 4.4.6 is amazing. It's what stock should be but won't because of politics."
Hyperbole aside, I'm inclined to agree.
.I've got it set at 160. I've just backed up my PESA settings and gone back to 'stock' 4.7 and re-run all of the tests again - can't see a single difference on any device anywhere in the house and every test is within 1-2%, so margin of error.Certainly sounds like it is a possibility (and most likely). Whatever firmware you run won't alter hardware limitations of the client or defeat the laws of physics.
One thing to bear in mind is the Pesa builds contain a lot of patches and upgrades that will never make it into 24.10 (or later versions, hence the mention of politics I quoted above) which aid stability, range and compatibility, which is my main concern. Performance being a happy and welcome coincidence.
I originally moved onto Pesa because of issues with Apple (which it solved; issues somewhat like the OP posted), but as a family we have Android/Windows/Linux/games consoles as well as IoT devices, which it does the business for.
The reason for me staying on 4.4.6 of the Pesa build is a number of major changes have been made and the kinks are still being worked out, wheras 4.4.6 is the culmination of months of tinkering by the dev and others. This will be done in time, and I'll move on then.
Edit: Do you have your 5ghz band set at 80 or 160? As that will have a bearing.
On stock 4.7, leave your house and go out of WiFi range and then return and see what happens.I've got it set at 160. I've just backed up my PESA settings and gone back to 'stock' 4.7 and re-run all of the tests again - can't see a single difference on any device anywhere in the house and every test is within 1-2%, so margin of error.
Just tested this - walked to the end of the road and back - only thing I noticed was that it connected to 2.4ghz first (I have the 2.4 and 5ghz set up with different names) as my phone saw that network first as I was walking back - but speeds on that network are just the same now as they were before I leftOn stock 4.7, leave your house and go out of WiFi range and then return and see what happens.
Some of the devices we have would reconnect automatically but with really poor throughput.
Seems your getting the full potential from your clients. Great stuff.I've got it set at 160. I've just backed up my PESA settings and gone back to 'stock' 4.7 and re-run all of the tests again - can't see a single difference on any device anywhere in the house and every test is within 1-2%, so margin of error.
Yeah it's the 5ghz that's the issueJust tested this - walked to the end of the road and back - only thing I noticed was that it connected to 2.4ghz first (I have the 2.4 and 5ghz set up with different names) as my phone saw that network first as I was walking back - but speeds on that network are just the same now as they were before I left
Tested again after turning the 2.4ghz radio off. Same result as before, speed test to the router before leaving (1200 connect, 600 throughput) is exactly the same when I return from a walk down the roadYeah it's the 5ghz that's the issue
I've just tried to add the same package on one of my own Flints running 4.4.6. Same error as you've encountered.I've enjoyed playing around with OpenWRT today, but I can't get Adblock to install on 4.4.6 of the Pesa build - as it just throws an error every time when you go to install it
Thanks for confirming that, good to know it isn't just me. I also had a quick go with 24.10 openwrt, but that seems to have a bug that disables the 5ghz WiFi if you select 160, dropping to 80 and it comes back on.I've just tried to add the same package on one of my own Flints running 4.4.6. Same error as you've encountered.
I've read in the Pesa thread issues installing Adblock (or Ad something) before. So may be a known issue with a workaround.
I use Pi-hole so haven't encountered it personally.
