- 25 Nov 2005
You would need to limit the power to 200w if you're concerned about the problem though, the issue isn't the high power the card pulls, the issue is "IF" 5 of your 6 power wires fail and the high power is then forced through a single wire which results in a very hot wire, there's not really any sensible mitigation apart from a redesign of the PCB or putting sensors on the wires to see how much power each wire is drawingYou can. just apply a power limit on msi afterburn
