Great monitor since Ive had it. Enjoy.Nvidia reflex 2 isn't available on 4000 series yet and you don't have MFG. Didn't mention the graphics.
In other news, my 5090 and pg32ucdm is out for delivery![]()
How many reported cases of melting are we currently up to? Are there any comprehensive sources outside of that Reddit thread?
I'm livid look how my card and monitor came
Disgraceful that an expensive item is delivered like this! I've got my 5080 being delivered from the same reseller and I'm wondering what state that's going to be in! Are you going to install the 5090 or return it?No outer box for the 5090, not even sealed. Condensation inside.
https://i.~ibb.co~/rf55qrJL/20250215-112934.jpg
image hosting forum
Monitor box broken
Pg32ucdm elsewhere
5090 a competitor
Will check it, but it's nuts to me. Surprised there was a card inside tbh. It was literally an opened box no sealDisgraceful that an expensive item is delivered like this! I've got my 5080 being delivered from the same reseller and I'm wondering what state that's going to be in! Are you going to install the 5090 or return it?
Mine has just been delivered by DPD and was in a plastic sealed bag, so yours is definitely not "right" in terms of delivery!Will check it, but it's nuts to me. Surprised there was a card inside tbh. It was literally an opened box no seal
I agree, the card is cold and clammy to touch and has a feel of condensation to it too. I'll let it come up to room temperature before attempting to install.That's not much better though, wtf
I ordered a PS5 anniversary controller from the same company and it only arrived in a bag as well, so the packaging was all crushed.
I complained and got a £20 voucher as an apology. Just glad I bought the controller to use, not to collect
On mine, the perforated tabs on the box had not been opened, checked that first thing.Will check it, but it's nuts to me. Surprised there was a card inside tbh. It was literally an opened box no seal
The competitor is willing to offer me £20 compensation voucher. Imagine if I sent this back to them like that with no seal or anything.
Offering you 1% compensation? Sounds like a deal to me…The competitor is willing to offer me £20 compensation voucher. Imagine if I sent this back to them like that with no seal or anything.
Nuts that that is all they are offering! I hope the card works if you do keep it that is!The competitor is willing to offer me £20 compensation voucher. Imagine if I sent this back to them like that with no seal or anything.
So from my understanding, the state relayed over the sense pins as to the capabilities of the PSU just prevents people from using underpowered PSUs for GPUs. It does nothing to help with melting connectors. The *shorter* sense pins obviously help slightly with ensuring the plug is properly inserted. They were too long before and the GPU would happily pull current over a plug that wasn't fully inserted because the sense pins still made contact, causing melting. HOWEVER it seems now that that wasn't really the main issue all along as evidenced by the fact that nothing has really been solved and cables are still melting. Remember that a plug could be fully inserted but there could still be problems with the pins inside the plug or the cable itself. I don't know if you've ever seen one of these pins outside of its plug housing, they have teeny-tiny metal barbs holding them into the plug. It's not difficult to pop one out. I was doing some cable re-routing the other day and accidentally pulled a pin out of an 8pin plug (I had a spare so completely replaced it). This is why the GPUs need safety features to cope with faults in individual strands.I have a ‘really into the weeds’ technical question regarding the PCIE 5.1 spec - hoping that someone could clarify this for me.
There’s quite a lot of info available regarding the increased options available for Sense 0 and Sense 1 pins in the new 12V-6x2 spec:
ATX v3.1 & PCIe CEM 5.1 are official! - Hardware Busters
ATX v3.1 and PCIe CEM 5.1 are official. The key changes: the 12V-2x6 connector replaces 12VHPWR, plus a shorter hold-up time and revised excursions.hwbusters.com
I’m struggling to understand the significance of the new options being available for 0w and 150w power states.
From the second link above:
^^^ the formatting there could be a LOT better but it looks like the first table is for the new standard, whereas the second table is for the old standard.
From the first intel link:
I’m currently sat here thinking… “but what does it all mean, Basil?!”
I understand that the new pin lengths help ensure a more robust connection (hence H++ being better) but I’m ultimately trying to understand if the info I’ve set out in this post (re: SENSE0 and SENSE1) is, or isn’t, an additional reason to be weary of using a H+ socket with a 50 series card. It might be a total nothing-burger, but I’m not sure.
Any thoughts, oh wise ones?
The only knowledgeable person to actually put a number on what he considers an acceptable power draw on these cables is the Intel engineer. He said around 375w. He did say the 5080 was cutting it a little fine. The 90 series cards are unsafe in his opinion. This kinda tracks with what you see in terms of reports online for different GPUs. AFAIK 4080 Supers and below seem to be fine.And these 12VHPWR cables... would we reckon the fire/melting risk is less on lower power cards like 5070ti and 5080? Is there any implementation of these where they can be safely used?.
