silk/kitchen paint issues
27 Mar 2004
Telford
im in the process of some painting and need some advice with my kitchen please
the previos owner has used some silk or kitchen type paint i guess for easy cleaning and its causing an issue
i lightly sanded some down and repainted with silk paint and in some places it can be easy removed
ive let it dry and am currently sanding the whole kitchen down so it has a better surface to adhear too
my question is as i only want to paint once
what type of paint or what do i do?
i like the silk paint but now thinking a kitchen matt paint would be better as it would show less imperfections
i really just want to paint it once and thats it and it to stick properly this time
what can i do?
Maybe look into some of the Zinsser range, they make all kinds of stuff for problem surfaces
Guardz might be the stuff you need
Probably because it wasn't sanded evenly, then again if it's in a kitchen you could probably sand for days and still end up with a bad surface as every surface in a kitchen will collect a thin film of grease from cooking and sanding tends to move the grease around more than remove it.
Personally i would wash the walls with sugar soap in a kitchen rather than sand them.
Again personal preference but i wouldn't use a matt paint on anything but ceilings due to how easily it picks up scuff marks and how it's all but impossible to clean them off without repainting.
I would (and have done with my kitchen) light sand down to remove and nibs and bits, as above Zinsser - have a look at Gardz or BIN.
Paint with Dulux kitchen or wipeable/hard-wearing paint, matt, x2 coats.
thanks for the replys
i originally sugar soaped the walls, but now i have sanded as best i can and sugar soaped again
im going to
zinsser the walls
fill the paint edges with some fine filler and then sand down when dry
and lastly some kitchen matt paint as it should be more forgiving with the finish than silk kitchen paint???? johnstons kitchen paint will be used
i think there were x2 mistakes, x1 the previous owner did not prep correctly and i did exactly the same
I use Zinsser Allcoat matt in bathrooms and kitchen, sticks to almost anything. Or Zinsser Mould Resistant paint, but that needs three coats.
