I think so yes, I'm with three and it's a bit of a fiddle.As far as I'm aware Plex can still be used, and use remotely on the free account? Other options include Jellyfin of course with no paid options.
Not sure if it's the same for the alternatives, I've used Plex for years and depending on your home network where the server will be based, it should just be a case of forwarding one port. Was it the port forwarding you had issues with?
Is this Three's 5g home broadband?I think so yes, I'm with three and it's a bit of a fiddle.
Yep that sounds like a fiddle![]()
I will give this a go when I have the chance, thanksIs this Three's 5g home broadband?
If so, try going into your router's APN settings and change the mode to Manual, the profile to "Custom" and the PDP type from the default IPv4v6 to IPv4 (this is with the ZTE router, I presume the Zyxel will be similar). Also make sure the APN is "3internet" and not "three.co.uk" otherwise you'll probably be on CGNAT which will cause port forwarding issues.
I never got that working, I think it's the problem above which I'll try ASAP.Synology does have their own QuickConnect service for remote access although i would look at Cloudflare's Zero Trust (Tunnels), requires your own domain name, if you're wanting to use Plex etc.
You can’t stream video via CF’s tunnels - against terms of service.Synology does have their own QuickConnect service for remote access although i would look at Cloudflare's Zero Trust (Tunnels), requires your own domain name, if you're wanting to use Plex etc.
