- 29 Jan 2003
OK so the two water-cooled systems I've built have used combination reservoirs and pumps: nice and easy, no thought required. I decided I wanted to get clever though and combine this:
www.overclockers.co.uk
... with a pump. Sounds like a plan - except I have no idea what I'm supposed to actually buy to go with it
Is it as simple as buying something like this:
https://www.overclockers.co.uk/bitspower-d5-top-reservoir-digital-rgb-pom-wc-66v-bp.html
Or do I need extra bits? There's clearly more to it than I realised and I'm confused. Has anyone got any advice / tips on what I should be looking for?
Barrow T Virus Helix 255mm Reservoir - White
Order Barrow T Virus Helix 255mm Reservoir - White now online and benefit from fast delivery.
