- 1 Jan 2003
- Derbyshire
Can we change the title to the 4090 smug owners club
Can we change the title to the 4090 smug owners club![]()
Needs 140mm fan me thinks![]()
If you aren’t having issues definitely do not check it. You will run the risk of causing an issue with re-plugging. Unless you have a clamp to check voltages I wouldn’t bother. If you need to remove gpu for another reason then great idea to check anyway, but I wouldn’t force it. Just my 2c.4090 owners are you all still actively checking for signs of melting power connectors?
It's been a nearly a year a now since I last unplugged and checked mine. I probably should check it soon.
Definitely true that you need to be able to plug a cable in properly, but it doesn’t change the fact that Nvidia made the cable inherently dangerous and that it can fail for reasons outside users being able to plug it in correctly.Nope.
I've removed my 4090 fe several times in the last couple of years (testing other GPU's) and not once have I questioned my ability to plug a cable in.
Not really given it a thought, I’m too busy enjoying gaming. I’d rather leave worrying to the 600w 5090 boys.4090 owners are you all still actively checking for signs of melting power connectors?
